engine combo help
Old Jun 30, 2009 | 09:08 PM
schottout's Avatar
engine combo help
hi i have a 350 with flat top piston stock bore a set of stock vortec heads with the .015 gaskets the summit intake for vortec heads headers and the edelbrock 2102 cam kit and a 600 cfm holley carb about how much hp and torque should this set up have also is the any suggestions on what spark plugs to you thanx also would my compression require 93 octane gas
Old Jul 1, 2009 | 01:35 PM
schottout's Avatar
Re: engine combo help
well anyone
Old Jul 1, 2009 | 02:14 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
just a wild guess but
290 hp, 320 tq
I would just run an AC Delco plug (45T I think)
Not sure on the octane. Assuming 64cc head (is that what vortecs are?) the usual flat top would be around 9.5-10:1. A thin head gasket would increase that so, maybe 10-10.5:1?? I would run it if it were me, but I run high test in all of my babies.
Old Jul 1, 2009 | 02:23 PM
3rdgenmaro's Avatar
Car: 88 IROC
290 hp, 320 tq
Old Jul 3, 2009 | 03:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Vortecs are actually closer to 61cc, so you're around 10.5:1, you'll have to run premium with a cam that small. I'd go to the Lunati Voodoo that has 219/227 duration at .050", and 112 degree lobe separation. That's the smallest thing I'd run. And even then I'd install it 4 degrees retarded from how it's ground. This would put you past a horse per inch, and with the right intake and exhaust, you could reach a corrected 400 crank hp, but that would be with no accessories.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
