Performance Help
Old Jul 9, 2009 | 01:29 AM
ironman607's Avatar
Performance Help
Hey all I have a 91 firebird 3.1L v6 fuel injected automatic. What I am looking to do is either better the v6 or is it possible to put in a bigger engine. So does anyone know good performance upgrades that will make my v6 faster or what engine swap can I do. Thanks
Old Jul 9, 2009 | 08:07 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Performance Help
Dont play around with the V6 its just money down the drain. Upgradeing is the way to go. Just drop in a 350 and a V8 700r4 and your good to go.
Old Jul 9, 2009 | 05:54 PM
ironman607's Avatar
Thats the thing will that bolt up into what i have and do you have any guess as to how much that could be.
Old Jul 9, 2009 | 07:55 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I agree, a swap to 350 would be best for performance. I would swap in a LS1 V-8 engine form a 90's camaro/firebird. It might be a good idea to buy a junk car to use for donor parts (engine, transmission, wire harnesses, rear end, disc brakes, etc).
Have any pictures of your bird to post?
Check out these posts in the Engine swap section. They should give you a good head start.
https://www.thirdgen.org/forums/engi...1-lt1-tpi.html
https://www.thirdgen.org/forums/engi...third-gen.html
https://www.thirdgen.org/forums/engi...swap-read.html
Old Jul 9, 2009 | 08:21 PM
ironman607's Avatar
i agree as well that swap would be good but unfortunatly im trying to do the best for the money which is my biggest problem. since i dont have the tools myself i would have to send it to a shop and the labor i would imagine would be expensive plus i would have to upgrade the rear and front and other stuff to support a v8. i was considering putting a performance chip, cam, performance intake manifold, performance thermostat, and k&n intake. only i dont know where to go to get a cam or if i can even get one for a good price that will work. any tips?
Old Jul 9, 2009 | 08:55 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
If your stuck on a V6 the best thing to start looking into is a turbo.
Old Jul 9, 2009 | 10:56 PM
ironman607's Avatar
i was thinking of putting a turbo on but the turbos i have seen run as much as a new engine would. do you know a type specifically that would work?
Old Jul 10, 2009 | 06:31 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I dont know alot about turbos but I found this on ebay
http://cgi.ebay.com/ebaymotors/TWIN-...Q5fAccessories
Go to the power adder section in here and ask what you will need to do to throw some turbos in your car.
https://www.thirdgen.org/forums/power-adder/
Old Jul 10, 2009 | 11:01 AM
ironman607's Avatar
thanks so much for the help
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
