help; starting an engine for the first time in 8 years
Old Aug 9, 2009 | 07:06 PM
  #51
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: help; starting an engine for the first time in 8 years
Originally Posted by 02v8ta
alright guys, update, it's been awhile. The car started! i had my friend come over at about 8 or 9 one night, i was trying to remove the spark plugs and couldn't. he wanted to see/hear the engine crank so hooked it up to the jump box and gave him the keys, he turned the key and omfg it turned over. i looked at it, screamed, and ran on the street yelling for my neighbor to come out. it ran for a good two minutes before i took the jump box off and it died about 30 seconds later. i was pissed i wasn't the one who got it to turn over but hey it started finally. It didn't even sound like it cranked for more than a second it just started like nothing... now monday i'll hopefully have the title in my hands and the whole restoring project can begin (yes i probably should of gotten it first but if i was just going to end up parting it out no point, and if the "owner" of the car can't find the title i'll be crushed)
Now with this said how the hell do i get the spark plugs out, i thought it was a 5/8 socket, took the 5/8 spark plug socket to it and wouldn't go on, i can't tell if it's to small or it's not getting all the way down to the plug for some reason. is there something i'm missing for removing these?
If its the stock Delco plugs, then yes, Its a 5/8 Spark Plug Puller.
If its aftermarket, It COULD be diffrent. Im no spark plug expert.
Old Aug 11, 2009 | 05:17 PM
  #52
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Alright guys update and more questions please help!
still can't get the plugs off, i'm half tempted to just change the wire set but i want the plugs off too. i'm 99% sure it's a 5/8 but i think either rust or debris is keeping the socket from going on the plugs fully. Is it safe to spray anything on the plugs and around them to try and get it cleared? i don't really have anything to blow it clean with. it does run i promise, sounds good for a stock v6.
http://www.youtube.com/watch?v=lKK7iVYH0Sw
sorry about the link(s), don't know how to embed on this website, but i'd appreciate you taking a look at them, they're more detailed than my descriptions can probably be. After it was running a few minutes this
http://www.youtube.com/watch?v=mGl0CA3ecMQ
(whining) noise started and i got worried but i quickly found it's the fan when it kicks on making it, does this mean the fan motor is going, is there anything i can do to help/ save it?
Finally after i started for the 3rd or 4th time today it started ticking...
http://www.youtube.com/watch?v=4-BsdxGfdaI
could this simply be some of the old gas getting to the engine? or something else, my friend told me to get lucas fuel injector cleaner for it, don't know if that would be bad in anyway to do that?
ALso what does this go to? it sucks air but idle's real low if i put my finger over it. Name:  227734da.jpg
Oil pressure dropped real low too while it was running today, don't know how accurate it is seeing the fuel gauge doesn't work but all the others including the oil gauge seem to work. This is while it was running..
Old Aug 11, 2009 | 06:10 PM
  #53
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
hmmm sounds like its starving for oil, sounded nice and quiet earlier too, hmm maybe the oil pump is on its way out?
Old Aug 11, 2009 | 07:38 PM
  #54
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
that does not sound good my friend
Old Aug 11, 2009 | 08:05 PM
  #55
Towman84Z's Avatar
sounds like it might have spun a bearing
Old Aug 12, 2009 | 11:16 AM
  #56
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
it seems like the oil pressure fluctuates, especially after it's warmed up, is that a sign of the oil pump going out?
That ticking didn't start till about after the 3rd time i had it running and was warmed up pretty good. Obviously i have to go see if it's still there next time i start it but what am i looking at as far as diagnosing the problem? Is a spun bearing a major issue/repair?
Old Aug 12, 2009 | 12:57 PM
  #57
Chevy8588's Avatar
that oil pressure is entirely too low, probably spun a bearing
Old Aug 12, 2009 | 01:47 PM
  #58
Towman84Z's Avatar
you'll have to pull the motor and and then the crank, it will most likely have to be turned after a spun bearing
Old Aug 12, 2009 | 02:41 PM
  #59
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I wanted to ask, did you prime the oil before starting the car? or just started cranking it after the oil change
Old Aug 12, 2009 | 02:49 PM
  #60
Chevy8588's Avatar
i think he just tried to start it without pulling the plugs and spinning the engine to prime it without compression putting strain on the bearings
Old Aug 12, 2009 | 03:05 PM
  #61
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Didnt put fresh oil in her before running it? Sounds like a bearing to me...and the super low oil pressure supports that. Red on the gauge = Bad.
If it was just the gauge going wacky, without the knocking, I might say the sender is taking a crap. If you want to know for SURE what the oil pressure is, hook up a mechanical gauge and check it. But im betting bearing issues...
J.
Old Aug 12, 2009 | 05:52 PM
  #62
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
I changed the oil & filter, siphoned the old gas out and turned the engine by hand before cranking it, couldn't and can't get the plugs out... so this caused a bearing to go?? or could this have been a pre existing thing? they did put it in the woods 8-9 years ago for a reason.
Old Aug 12, 2009 | 07:04 PM
  #63
Towman84Z's Avatar
whoever parked it probably had the same problem with the oil pressure. When you ran it with the oil pressure low like it was, most likely spun a bearing
Old Aug 12, 2009 | 08:46 PM
  #64
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
alright so run it until a rod comes through my oil pan to confirm spun bearing correct? ughh but seriously i see two options now.
1. full engine tear down. Is it even worth it? cost of repairing it, it's a v6, 2.8l, just a basic firebird model, body is in bad shape as it is
2, find another 3rd gen to spend my time restoring. I want to restore a car i have my heart set on it now but this one might be more than i can handle currently.
and is there anything besides a full engine tear down to confirm a spun bearing. i guess i'll have to go spend another day with it maybe tomorrow but more than likely saturday and see what's up with it... i'm kinda bummed after all this, thought everything was going to smooth to be true
Old Aug 12, 2009 | 08:59 PM
  #65
Car: 86 Trans AM
You have a loud rythmic knock, and hardly any oil pressure. Assuming the gauge is correct, you have a bearing issue. I really wouldnt even waste my time tearing that motor apart...unless you are purely curious. If you are set on fixing that car up, pick up another v6 motor/block and swap it in. Thats a fairly simple process as far as motor work/repairs go. Or...rip out the drivetrain, and swap in a v8 if you are feeling ambitious.
Just be honest with yourself. If you dont think you can handle digging into the mechanics, and you'd rather just tinker with body/interior stuff, then maybe this isnt the car for you. Im sure you can find another car that is in better shape that wont break the bank. I will say this...if you do decide to fix this car up, seeing as how it needs a TON of work it seems, the feeling of accomplishment you have when its finished will be pretty awesome.
Just dont dig yourself in so deep that you are stuck with a half apart car that doesnt run...its easy to loose steam. Like I said, dont "not try"...but be honest with yourself at the same time.
J.
Old Aug 13, 2009 | 09:43 AM
  #66
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
sounds like a rod to me
I'd get another v6, maybe even the 3.4, and swap it in using all of your hardware and the transmission you have. That reminds me... Before you spend some money on an engine, drive it around a bit to see if the transmission works as it should.
I know you can do it... I went through the same thing with my car. A few months after I got it, I was on the highway in traffic and the oil light came on.... It would shut off when I revved it, but the next time I changed my oil it was shiny
Old Aug 13, 2009 | 09:55 AM
  #67
Chevy8588's Avatar
V8 SWAP!!!!
Old Aug 13, 2009 | 01:36 PM
  #68
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
J.
I'm torn between what to do. Part out this car and buy another 3rd gen i can mess with or really get in deep with this car. i do want to "tinker" with body and interior but also wanted the engine to "tinker" with. A engine tear down or swap is more than i wanted currently. I fully expected this car to be a process over a year at least but pulling the engine and a rebuild practically wasn't on the list. I pretty much wanted something to bring back to be better than original quality and show room worthy, not make a street rod which is what this would turn into, i wanted light engine work.
another v6 swap is relatively easy correct? would a 3.4 go in with the same ease as a 2.8?
hmm the car has no interior currently but is driveable (on my proerty) tranny seems to move the car from point a to b fine. ah! Jack up the rear and see it the tranny shifts right that way???
ohh i should change the oil again.. see if it shine's.. should i even bother trying to get it to start again to confirm or just drain the oil now? would it be instant shiny oil if i did spin a bearing that last time i had it running? or start it up again before i do this... lots of questions, sorry
Originally Posted by Chevy8588
V8 SWAP!!!!
isn't a v8 swap the mother of all things i could do to this as far as time, money and work go? there is alot of fabricating to do this too right?
Old Aug 13, 2009 | 01:54 PM
  #69
Chevy8588's Avatar
im in the process of swapping a 305 TPI into my old 85 2.8 l, there is no fabircating to do, buy a complete running engine and transmission with the harness and computer, (ripped mine outta an 88 donor car with floor holes big enough to drop a large child through that i paid 250 bucks for just to get it off someone property, runs amazing!) move the 2.8's motor mounts foreward to the front two holes, put the tranny on (took me and hour with a floor jack and hoist) then drop the engine in, put the v8 radiator and fans in, bolt it all up, connect the fuel lines and your done. it is VERY easy if you hae a donor car, mines taking longer cuz i decided to do a ground up restore and refreshen on the car. the stock fuel pump will supply enough fuel for a 305 easily, and everything else is the same. the v6 had no ***** compared to my 305, which i installed a light cam and valve springs in too, things gunna make some good torque and HP too. a V8 swap can be done in the course of a weekend if you have a donor car, then have the junk yard drag the remains off when your done with it. i even took all the triangulr frame ties off the 88 too and put em on the 85 after stick welding the cracked frame rail back together (ugh) those combined with tehe wonder bar, solid strut mounts, a strut tower brace and SFC's i will never have a cracked rail again or body flex for that matter, lol
Old Aug 15, 2009 | 01:25 PM
  #70
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Still a toss up on if this is going to be a parts car or fixer upper. started messing with it today and it ran fine... no knocking oil pressure was fine, engine warmed up and pressure dropped alittle but still within normal. Is it possible the noise/ knock was a noisy lifter? or the knock of a spun bearing is normal to go away?
NEW ISSUE! heater core blockage
need to pull the heater core? is this something that you can pull or fix or needs to be replaced?
Old Aug 15, 2009 | 03:04 PM
  #71
Car: 86 Trans AM
Thats weird that the knocking comes and goes. TO me, it sounded too heavy/loud to be a lifter. Lifters usually tick. That was a knock. The oil pump could be taking a crap. Might not have spun a bearing yet, but running it with insufficient oil pressure will eventually destroy them. And quick too.
That looks like a heater core leak. Thats a fun job to fix. If you want to keep it from leaking and avoid fixing it right now, just unhook the hoses, and either connect them together or plug them. Im not positive on how the v6 cars are set up for coolant flow. But I would avoid running it with the core hooked up because its just gonna keep putting coolant inside the car.
J.
Old Aug 15, 2009 | 04:46 PM
  #72
Chevy8588's Avatar
dude, those floor pans look pretty damn decent forwhere it sat, you paid nothing for this car right? so everything you do to it is gravy, fix that bad boy!
Old Aug 15, 2009 | 07:41 PM
  #73
Toehead's Avatar
Solid floor pans. You're golden!
You don't need heat down there in jersey Bypass that bad larry.
Maybe the oil pump is just all gummed up (the pickup screen) Now that you have run it for a while, drain a little oil (cold) add a quart or so of atf, run until it's a little warm, and then change the oil. Don't do anything but idle with the atf in it.
Old Aug 15, 2009 | 10:57 PM
  #74
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
i believe i'm going to have to pay $1 to get an actual bill of sale from the guy/ friend the car came from but yeah i got it for nothing. The rear where the passenger seats were are worse than the front, pretty rusted.
The tick/ knock went away and the engine temp got pretty close to normal operating temp before the heater core went... oil pressure stayed up. it would be awesome if that noise was a lifter and not a bearing. Would a spun bearing noise/ symptom come and go like that? i'm hoping the engine is "savable" without a tear down. Maybe an new oil pump, heater core and it'll all be good? (wishful thinking going on here )
Old Aug 15, 2009 | 11:14 PM
  #75
Toehead's Avatar
To answer your question, the 3.4 swap is pretty much plug and play. There is a sticky on the v6 board about the swap. You yank out your 2.8, use your intake and accessories on the 3.4, and put it back in.
As for the noise, it was pretty loud. Maybe you got lucky and nothing is "seriously " screwed up... I don't think it was a lifter, it really does sound like you lost oil pressure. If the pressure is back, and stays up, what's the harm with driving it? You got it for free! It'll let you know really quick whether or not it is damaged!
I'd try the ATF thing to get all the gum out of the oil pan, then just work on the body and interior. Maybe purchase a 3.4 liter and have it on hand, then once the rest of the car is alright, register it and drive it until the motor blows (or doesn't blow, depending on the damage )
Old Aug 15, 2009 | 11:18 PM
  #76
Toehead's Avatar
Here you go. 200 dollar 3.4
http://jerseyshore.craigslist.org/pts/1321695579.html
Old Aug 15, 2009 | 11:20 PM
  #77
Chevy8588's Avatar
well to be honest how loud was that knocking? cameras do tend to make ticks and such nound much worse than in person, it COULD have been a deflated lifter, a spun bearing does NOT knock on and off like that, and a loose rod will not do that either, trust me, my caddy has had "crank lash" as GM calls it due to a bearing in the number 1 seat for 100,000 miles, put a new pump and bearings in her today actually, totally silent lol, anyways, if i were you man, i would not cross my fingers and hope, i would rip that engine out, the 2.8s blow head gaskets and get close to the same mileage as a TBI 305 in good condition anyways, and to replace the oil pump you gotta pull the engine no matter what, the K-frame is in the way of the pan, i'd drop an 8 back in and sell the 2.8 off, also if this car is never gunna see winter again bypass the heater hoses, get a pass through and run the hoses into eachother, then fix it when you can, you definately have a good foundation here, cut any rot out and weld in some sheet metal, undercoat it and keep it out of the winter and you will have a great car here man.
Old Aug 15, 2009 | 11:59 PM
  #78
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Thank you all for the advice, i think if the engine is runnable for now, i'm going to run it until it blows. If i do an engine swap it'll probably be a 305 (if someone was able to help) just because i don't see a point of putting another 6cyl in there besides ease of work. ( i might be able to accomplish that one myself.) I'm still alittle confused on what i would have to do to the motor mounts to make it work. And wouldn't i need another rear end too, or not? if i did go this route ever in the future anyone on here is welcome to come help me...
I think like you suggested Toehead i'll run it until it blows or doesn't blow... No matter what i think between thinking things out online and talking with you guys i'm keeping this body and will restore it with or without the 2.8L. More than i expected but i can't let it go now. The passenger side fender is my biggest body issue and has me worried but that's a topic for a different section.
Old Aug 16, 2009 | 12:12 AM
  #79
Chevy8588's Avatar
the passenger side fender bolt right on, call certifit, they have new relacements for 35 bucks. also for the V8 swap, you unbolt your motor mounts from the k frame, (now is a goot time to replace em, 8 bucks at napa) and there will be a set of holes drilled foreward on the k frame, bend your brake line backa bit and bolt the mounts in the foreward holes, you will need an engine and transmission combo, your current differential will work, and just cuz it limps does not mean the tranny will shift, if the trans is blown, you may as well spend 500 bucks on a good running donor car with a crap body and do a power train transplant, is really alot easier than it sounds. trust me, its just nuts and bolts, it all goes back together the same way it comes apart, after i got over my fear of taking things apart i really took off on it, im a laid off level 1 certified hyundai tech, with NO schooling, and i STARTED working in a cadillac dealership, (where i bought my cadillac) and transferred to their hyundai dealer to avoid a lay off becuase of GM, and then got laid off because of the crappy economy :/
Old Aug 16, 2009 | 11:32 PM
  #80
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
heater core = big pain in the ***
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
