need distibutor help
Old Jul 28, 2009 | 03:20 PM
schottout's Avatar
im having trouble with getting my distibutor to sit all the way in any advice or suggestions thank you
Old Jul 28, 2009 | 11:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need distibutor help
You have to wiggle it and work it in. The top of the distributor has to be free to spin while it's being inserted.
Old Jul 29, 2009 | 12:04 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Be very carefulkl here. Im mean extremely carefull. if the dizzy wont drop all the way in, its because the oil pump drive shaft is not lined up with the notch at the bottom of the dizzy shaft. So carefull now, get a long flat head screw driver make sure its clean, stick it down into the hole and with a flash light , turn the oil pump shaft until you believe that it will be lined up with the notch under the dizzy. MAKE SURE that you dont nick anything inside like for example the camshaft. And dont drop the screw driver in either. Anything else bro?
drain89
Nov 10, 2003 02:42 PM
TPI86TA
Sep 29, 2003 09:12 PM
TPI86TA
Sep 28, 2003 03:34 PM
butters8435
Sep 7, 2003 02:06 PM
fazool
Jan 7, 2001 04:01 PM
