valve guide/head question
Old Aug 7, 2009 | 06:58 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hello all,
I'm not experienced with heads and machine work, so I'm hoping you can help me here. I just purchased a set of used heads that were machined for 2.02/1.6 valves. one of the heads is normal, the other appears to have had the valve guides drilled and re-sleeved (see photo). Is this acceptable or do i have to be concerned about this head failing? thanks in advance!
Old Aug 7, 2009 | 02:45 PM
thunder85's Avatar
Engine: 5.7L w/hsr
Re: valve guide/head question
anyone?
Old Aug 10, 2009 | 07:56 AM
thunder85's Avatar
Engine: 5.7L w/hsr
Please... I need to know as i'm planning on installing these this coming weekend?
Old Aug 10, 2009 | 06:33 PM
cmack's Avatar
Car: 1983 camaro
Engine: 383sbc
as long as they are guides are tight they are fine and make sure the top of the guide is machined for the proper seals i work at a local machine shop and we normally use bronze liners in stead of drilling for guides but it is not a problem
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
