86 camaro over heating,help
Old Aug 9, 2009 | 07:15 PM
my86camaro207's Avatar
ok bought a 86 camaro and has a 350 in it,new radiator,new thermistat and electric fan.car still over heats,no leaks any where.why is it doing this??can any one help.
the guy said that there is only apx.5000 miles on motor,cant confirm that
Old Aug 9, 2009 | 07:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 86 camaro over heating,help
does fan come on? at what temp? single fan, or dual fans? overheat while driving hiway, or in traffic/standing still? fluid is 50/50 water/coolant? overheating (ie boiling), or just getting hot? Have A/C or defrost turned on? What is timing set at?
Need more info.
Old Aug 9, 2009 | 07:41 PM
Need more info.
turn the fan on at start up(toggle switch),single fan infront and clutch fan on motor,over heats while driving(all speeds) and at stand still,mix is about 75% coolant and 25% water,no ac,heater motor is stuck on(low) and not sure about the timing,when the motor gets hot it starts to ping under a load
Old Aug 10, 2009 | 11:19 AM
Car: 1992 RS
Engine: Carbed 350
ok. So I'm at a loss then.
You have the air dam under the car, right?
The thermostat - I know it's new, but it still may not work. Try taking it out, and boiling it in a pot on the stove to see if it actually opens.
Only other thing I can think of is waterpump - is it leaking? (little hole on backside at the bottom) is it correct model for this car? (there are standard rotation and reverse rotation pumps)
Old Aug 10, 2009 | 03:19 PM
pulled the thermostat out and its running between 205-230 then I pull over to cool down.is has z28 ground effects on it.the guy put a new water pump on(so he says) but no its not leaking.how do I know if the water pump is standard or reverse rotation?
Old Aug 10, 2009 | 05:32 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Maybe try a cooler t'stat? I never heard of a fan set-up like that. Some say no t'stat is the worse thing to do. As far as knowing if the CORRECT waterpump is on, I don't know how to tell the dif just by looking at it. Anyone know what year the reverse pump was used? Do you have a shroud of some kind?
Old Aug 10, 2009 | 05:35 PM
there is a shroud.the car was a 2.8 and now a 350
Old Aug 10, 2009 | 07:38 PM
Car: '87 Camaro
After reading another thread on over-heating--- do both fans PULL from the front,forcing the air across the motor? If they turn dif directions ( 1 PUSHING air to the front of the car the other PULLING from the front to make the air flow toward the motor ) then it's creating an oven ahead of the rad with no air circulating. Do either of the rad hoses collapse when the motor is @ normal temp when you rev the motor? Soft hoses also restrict flow. If you don't have the lower air deflecter,do you have the big plastic piece that goes between the front end & rad? It directs air into the rad. That's all I can think of.((edit)) What pressure cap is on the rad? Is the rad for a V6 or V8?
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
fonzie85
Aug 13, 2015 11:50 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
