Eliminate Engine Oil Cooler
Old Aug 12, 2009 | 11:14 AM
bdle's Avatar
Car: 1988 Camaro IROCZ
Axle/Gears: Stock
i just purchased a remanufactured engine from jaspers. i dont want to void the warranty by using the old oil cooler. i tried to clean it the best i can but im still worried about metal particles getting into the new engine. can i remove the cooler and attach the oil filter to the adapter that the cooler attaches too. (i really dont want to eliminate the cooler but i also dont want to void the warranty)
Old Aug 12, 2009 | 11:41 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Eliminate Engine Oil Cooler
Yes, you can remove the oil filter and use something like this http://www.summitracing.com/parts/SES-3-60-08-900/
Then just cap off the coolant lines.
Old Aug 12, 2009 | 12:07 PM
Stephen's Avatar
Car: 87 GTA
The factory oil cooler lines are for COOLANT, not the oil.
Metal shavings or not, from your old engine, they can't possibly be in the oil cooler lines.
Old Aug 12, 2009 | 06:47 PM
bdle's Avatar
Axle/Gears: Stock
i realize there wouldn't be metal on the antifreeze side of the cooler. But on the oil side of the cooler I was getting alot of gunk out of there when I was cleaning it out. i don't know if I got it all.
Old Aug 12, 2009 | 06:50 PM
bdle's Avatar
Axle/Gears: Stock
thanks but thats what my oil cooler mounts to. so i guess i can remove it, cap off the lines and mount the filter on that. thanks for your help
Old Aug 12, 2009 | 06:51 PM
Stephen's Avatar
Car: 87 GTA
I'd flush it with a liquid (in both directions), not just air. Or you could just buy a new one, if you wanted to keep a cooler. Aftermarket makes them too, not just GM.
Old Aug 12, 2009 | 08:14 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
are you talking about the transmission oil cooler located in the radiator?
that has no effect on the engine oil.
i have also never seen a radiator with engine oil cooling tubes in it, but i guess anything is possible.
what exactly are you talking about?
Old Aug 12, 2009 | 08:33 PM
Stephen's Avatar
Car: 87 GTA
Like this......
http://www.summitracing.com/parts/TRD-1313/?image=large
It allows coolant to flow through the spin on adapter, to provide another level of cooler, but directly to the oil itself.
Some 3rd gens came with them stock, most didn't.
Old Aug 13, 2009 | 05:56 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
mine came with one stock and by the time i got it. was leaking oil hardcore so i just took it off. easy as that
Old Aug 13, 2009 | 04:50 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
ok well if thats all it is, then no problem.
take it off and be done with it.
OR
get a new one, get a new cooler, and run it that way.
ive never seen a car come with one of those stock but anything is possible in the wide world of GM i suppose.
what do you have for a cooler anyway?
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
