wiring problems please help
Old Aug 18, 2009 | 08:47 PM
justtodd's Avatar
Car: 86 camaro iroc
Engine: 5.0 tpi
I have a 86 5.0 camaro with no power to the fuel pump relay.their is power to the fuse by the batt. could the ecm be bad? im lost in the wires any ideas.anybody?
Old Aug 19, 2009 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The ECM doesn't provide power to the relay, it simply grounds the magnetic coil circuit to energize the relay and close the power contacts.
If you don't have power to the relay, you've got a problem other than the ECM. Check fusible links first.
Old Aug 19, 2009 | 08:07 PM
justtodd's Avatar
Car: 86 camaro iroc
Engine: 5.0 tpi
Re: wiring problems please help
ok thanks
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
