flipped 92 Z28 now wont run
Old Aug 24, 2009 | 10:14 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Ok,first I did a search but no hits... I have bought a 92 Z28 tpi car that was flipped on its top...now when I turn the key on I don't here the fuel pump kick on...I was wondering if the thirdgens have a breaker type saafety switch to shut off the fuel in case of a rollover??any ideas would be helpful...it also has a python alarm on it,would this affect it?
Old Aug 24, 2009 | 11:19 PM
nzo's Avatar
nzo
Re: flipped 92 Z28 now wont run
Fuel pump problems seem to very prominent lately. Try this thread for ideas: https://www.thirdgen.org/forums/tech...problem-i.html Or my thread which is here: https://www.thirdgen.org/forums/tech...i-no-fuel.html , It may help give you a direction to start looking in. Good luck!
Old Aug 25, 2009 | 07:16 AM
dwillis's Avatar
Axle/Gears: 3:08
thanks abunch
Old Aug 25, 2009 | 08:22 AM
Stephen's Avatar
Car: 87 GTA
Your car got flipped over & your worried about the fuel pump?
I suspect you have a LOT of bodywork (if the body can be saved at all) to take car of, before the lack of a fuel pump is of any concern!
Old Aug 25, 2009 | 09:05 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
and what relavance does this have ot do with anything he asked. MAYBE he bought it for the drive train and wats to see how it runs before he puts anymore time into removing it all etc.
or nybe he is gonna fix the car.
to the op: check out the links above. Our cars DONT have a breaker like others.
1st. Id check the relay see if its cycling on with the key. Then work your way back to the fuel pump. have a multi meter check for power, etc.. Good luck.
any pictures of the poor car?
Old Aug 25, 2009 | 10:15 PM
dwillis's Avatar
Axle/Gears: 3:08
you hit it on the nose,I bought it for the drivetrain and to share the good parts with fellow thirdgenners,instead of it going to the scrapper..
I wanna hear it run before I dive into it...
pix coming
Old Aug 25, 2009 | 10:18 PM
dwillis's Avatar
Axle/Gears: 3:08
P.S.....My car is the 91 Trans Am...I just need the motor and tpi wiring since my wiring is jacked.
Old Aug 25, 2009 | 10:22 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
check the sensors?
Old Aug 25, 2009 | 10:24 PM
rutters27's Avatar
Car: 88 t/a 92 rs camaro 88 firebird
Engine: 305 tbi in both
Transmission: auto camaro 5spd firebird th375
Axle/Gears: 3.73 minispool
looks like it held up fairly well for being upside down good to see someone gutting it and letting it live on by the way where are you located garyberg just like to keep a list of bird people for future reference and your also a pennsylvanian
Old Aug 25, 2009 | 10:25 PM
dwillis's Avatar
Axle/Gears: 3:08
Originally Posted by Gary Berg
check the sensors?
naah gotta get back into it ...I'll check somemore stuff this weekend
Old Aug 25, 2009 | 10:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you just want to hear it run and don't want to delve into a powerless fuel pump issue, you could jump the ALDL and power it directly.
Old Aug 25, 2009 | 10:31 PM
dwillis's Avatar
Axle/Gears: 3:08
Old Aug 25, 2009 | 11:07 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If the pump is dead jumping the ALDL wont do anything. Give it a shot. Use a jumper lead from the fuse box 12v to terminal G on the aldl. ( bottom left on aldl)
If that doesnt work you can always cut the fuel line and run a extermal pump and hose into a gas can for now. That will let ya start ot up. Been there done that before.
Old Aug 25, 2009 | 11:24 PM
dwillis's Avatar
Axle/Gears: 3:08
Yeah I can jump it and see if i hear the pump run if not I'm gonna do the external pump idea because I have an extra one...thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Aug 16, 2015 08:01 PM
tmellott89
Aug 16, 2015 02:58 PM
