CAR WONT START! HELP!
Old Aug 26, 2009 | 11:20 AM
Jasper8391's Avatar
Car: 71 Chevelle
Engine: 85 305 TPI map
Transmission: 88 700r4
Hey, i own a 71 chevelle that i put an '85 trans am 305 tpi into. I then converted it to the '86-'89 setup. The other day i was welding on my car and i sure enough forgot to disconnect the battery (let alone turn the key from on to off) the next day my car would start for a split second then die off, and wouldnt even start for that split second again for awhile. I figured i musta done something to the computer, which is fine because i had all the materials to convert my car to MAP. I did so, and replaced the fuel pump 12v fuse, and the car does the same thing. Could this be a fried alternator, or something more elusive? Please Help!!
Old Aug 26, 2009 | 12:37 PM
Jasper8391's Avatar
Car: 71 Chevelle
Re: CAR WONT START! HELP!
Ok, ive checked a few things, and it seems as though im not getting any voltage to the injectors, anyone have any idea what could be the cause of this?
Old Aug 26, 2009 | 01:11 PM
cmtison's Avatar
Car: 1992 B4C
Engine: L98 soon to be 383
Hey i have a 92 B4C with the 350tpi i have been driving it for the past week or so and this morning i had the exact same problem.. started for a second then died and didnt get anything else from it except that it was trying to start when i turned the key just wouldnt start. im at work now but when i get home i am going to have my girl try to start it while i smell the exhaust. if i smell raw fuel then i know i have an ingnition problem if i smell nothing then i have a fuel delivery problem. hopefully someone can help the both of us.
Old Aug 26, 2009 | 02:46 PM
Jasper8391's Avatar
Car: 71 Chevelle
i found out its because my ecu isnt grounding my injectors, and all my grounds are secure. Do you think it could be vats? because i got both my new ecu and prom online and it didnt tell me whether it had it or not.
When you get home, pull a spark plug and press the tip up against the block and turn the car over to see if you have spark. If you do, then another test that i did was to pull an electrical plug from one of the injectors, and using a voltmeter, test the voltage during cranking.
Old Aug 26, 2009 | 04:09 PM
cmtison's Avatar
Car: 1992 B4C
how did you find out it was a grounding problem?
Old Aug 26, 2009 | 04:29 PM
Jasper8391's Avatar
Car: 71 Chevelle
I did the tests i told you about, then turned to key to the on position, and tested the voltage of the injector wires all the way up to the point where they enter the ecu. The ecu controls the injectors by grounding them. This gives them their normal pulsation. My ecu isnt allowing my injectors to pulsate, and im now positive that its vats.
Iv'e read online that vats is on every 90-92 camaro and firebird, and can fail at any time (so this might possibly be your problem too). I just upgraded my system to this setup and i dont have a vats bypass module, so im looking for a way to get one or replicate one.
Old Aug 26, 2009 | 08:07 PM
cmtison's Avatar
Car: 1992 B4C
Well strangly enough when I got home it started right up. I have no clue what it was doing this morning. But at least I know now what you tried the next time I have that issue.
Old Aug 27, 2009 | 08:10 AM
cmtison's Avatar
Car: 1992 B4C
i take that back. this morning it did the same thing started for a second but then died and wouldnt start after that. Is it a cold start thing ?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
