1987 GTA Headlights won't go down
Old Aug 31, 2009 | 03:52 PM
halfmoontrail's Avatar
They go up together, and used to go down together, headlights work fine. Apparently the 87-90 uses an ECM for the headlight buckets, do they go bad, can they be fixed?
Thanks in advance,
Steve
Old Sep 1, 2009 | 09:24 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 1987 GTA Headlights won't go down
Well they do go bad an thats probably your problem. They cant really be fixed. I mean theoretically im sure they could but its one of things without some background in electronics and a supply of old electronic parts not going to happen. Best bet is to go to the junk yards and fine a new headlight control module.
Old Sep 1, 2009 | 10:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Call Lon at Top Down Solutions (TDS). He advertises on this board. He will have the parts you need.
Old Sep 1, 2009 | 10:46 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
try turning the ***** next to them, like what three 6 mafia says, " slob on my **** like corn on the cob, check in with me and do your job" joke. could be faulty switch, stripped gears, or bad motors, relays
Old Sep 1, 2009 | 11:12 PM
Stephen's Avatar
Car: 87 GTA
Thanks in advance,
Steve
Wow. I just got through answering a similar kind of problem yesterday, in another thread. is your best friend.
https://www.thirdgen.org/forums/elec...t-go-down.html
The don't use the ECM your thinking of.
They use their own controller box, that is basically separate circuits inside 1 box, so if 1 side fails, the other should still work.
It's a square box on the firewall, drivers side, under the hood. With everything off & when they should be down, pop the hood & tap on it/lightly hit it. Chances are, it is a bad circuit sending the close signal to both sides (if both sides are bad).
If they go down then, you've narrowed down your problem search. 4 screws open it up & you can look inside for broken circuits, dirty relay contacts, etc. Wouldn't hurt to fold a strip of sand paper over & use it to sand/clean the insides of the mechanical contacts, while your in there.
Old Sep 2, 2009 | 03:16 PM
All pins and inside of module look great, doors still up. Anybody have any other ideas? The motors seem to "run-on" after the doors are up, is this meaningful?
I'll check my upull for another module.
Steve
Old Sep 2, 2009 | 04:07 PM
Stephen's Avatar
Car: 87 GTA
If the motors run on, that would indicate a bad circuit inside the motor itself.
The basic way they work is, when they hit the stop....The resistance increases, "overloading" the motor. When the resistance is seen, they are designed for the circuit to turn them off, as to not actually overload.
It is sounding more like a motor problem, than controller problem. Now that you mention the motor run on.
Old Sep 2, 2009 | 04:16 PM
That makes sense, but it is odd that both are affected, and it came on recently. The run-on has always been for both, and both opened and closed fine, and now both stay open.
Oh well, at least they are stuck OPEN!
Steve
Derick15
Sep 17, 2016 05:28 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
TA8487
Aug 16, 2015 12:21 PM
