305 TPI Help Please
Car: 89 Iroc
305 TPI Help Please
my engine has a bit of annoying problem...the engine when started floods and if it drops low on rpms, it dies. now i have a scanner and checked for codes. i got the knock senser, MAF, and i do believe the O2 senser. i say i believe so becasue its been since last november i've done any work with the car. i replaced the knock senser and the mass air flow. didnt help so i replaced the ECM, and it didnt help either. the only thing im thinking of is that maybe the ECM i got was bad. oh and when running, raw fuel comes out the exhaust...thanks i would love to get it running again
Car: 89 Iroc
Re: 305 TPI Help Please
i'll have to get back to you on that one. my battery is dead and i'm not going to deal with it, so i'll check tomorrow if i can. hard to find time between school and work.
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
stuck open injector. are you running stocK injectors 23 years old? its fuel related. that be cool to blow flames out the pipe, id have a killa time with that. But i wanna say stuck injector. test the Resistance on each injector. it takes about 45 minutes. i use a needle pin to carefully remove the clips. or the easy way would be to attach a fuel pressure gauge on the rail and prime her. shouldnt drop. past 32psi/max 45
Car: 89 Iroc
i would like to add some other little problems i am having...
RPMs read higher than scanner says
Spedometer is high
Fuel Gage doesnt work
Oil Pressure is also off
and i keep blowing my internal lights fuse
this all is driving me nuts. idk if i want to spend the 3k to fix and paint if i cant drive it...
Spedometer is high
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
how do you test the resistance on the injectors and what should it be? I'm having a similar problem with my tpi.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
In the berlinetta the MAF gets the power from the light module... just something to think about. I don't know if that applies for non -berli cars.
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
