L03 Heads
Old Sep 1, 2009 | 02:03 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
L03 Heads
I'm replacing seals and seats, etc because mine need to be reserviced, just curious what should i do thats cheap to get a little more out of the heads while i have them apart?
Old Sep 1, 2009 | 03:05 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: L03 Heads
what do you mean by "seats" any machine work is a waste find another set or a different casting
throw them in the trash...?
Old Sep 1, 2009 | 08:10 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: L03 Heads
no i'm blowing blue smoke so i'm reservicing my own heads right now.
Old Sep 2, 2009 | 09:53 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L03 Heads
Seats are not a DIY job. And they have nothing to do with blue smoke. If you want to do seals, that's great. No need to pull the heads, but if you do, then upgrade to the non-swirl-port heads used on the LB9s with 5-speed.
Old Sep 2, 2009 | 07:43 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: L03 Heads
swap heads your saying?
Old Sep 2, 2009 | 08:37 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: L03 Heads
Seriously, these are the worst heads GM ever made. Just about anything is better than these heads. A set of 350 vortec heads would be great, even the 305 vortec heads are far superior to LO3 heads.
Old Sep 3, 2009 | 09:47 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: L03 Heads
What should i do though? I don't know the appropriate casting of 305 heads, and people tell me i'll lose compression or it'll be hell working with 350 vortec heads on my 305.. ive been hearing good and bad reports on them and no ones giving me a straight answer. :\ I know that'll i'll need with vortec heads a vortec aluminum intake to tbi, and since i do that i heard a cam would help alot... (lt1 w/ vortec?)
Old Sep 4, 2009 | 04:42 PM
Car: 91 RS
Engine: 350 vortec
Re: L03 Heads
yes if you run the 906 or 062 vortec castings you will loose a bit of compression gonna guess .2-.5 but the power you will gain from just not running those other heads will more than make up for it but you are starting to get into the area of needing a new tune
Old Sep 4, 2009 | 05:42 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: L03 Heads
059 casting are good 305 vortec heads.
I would not invest in new heads if stayn under 5000rpm.
Old Sep 4, 2009 | 08:33 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: L03 Heads
well from what you all said those are 3 castings, and IF i remember correctly, each casting just has a slight different type of air flow chamber?
which one would be best if i get a different cam later? and maybe get a bigger throttle body?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
