key gets stuck in ignition
Old Sep 9, 2009 | 10:59 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
So my new trans am has a few quirks im slowly working out, this particular problem is quite annoying and started out happening maybe once a week to almost three or four times daily.
What happens is my key does not come out, it stops turning about a half a centimeter from the line on the ignition that allows the key to pull out of the ignition. The car is in park, i have tested it to make sure. I originally thought this was a problem with the cable from the gear selector to the transmission as this was replaced about 2 months ago. The remedy to this problem seems to be either starting the car and turning it off, which only works sometimes, also selecting through the gears from 1-P seems to work sometimes also. Any ideas on what this is?
Chris
Old Sep 9, 2009 | 12:20 PM
THETEEDOGG's Avatar
Re: key gets stuck in ignition
hey bud...for your key problem...most likely the ignition lock and tumbler...the tranny...try adjusting the shifter cable...i have seen these things get out of adjustment regularly
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
TexasMaro
Sep 15, 2015 06:50 PM
383cam
Sep 9, 2015 06:01 AM
