no power
Old Sep 14, 2009 | 01:27 AM
Qiroc85's Avatar
no power
so earlier i stopped at a stop sign and floored it but the car didnt burn rubber or take off that fast i have a 85 iroc with the tpi is that normal or is this engine just that slow? i know i need a tune up but what do i need to tune up like new spark plugs or wat? thanks
Old Sep 14, 2009 | 04:34 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: no power
did you just get this car? if so, then welcome to the universal disappointment that is the 305. Once it's tuned up, you can start improving your stoplight performance with a looser torque converter.
Old Sep 14, 2009 | 07:36 PM
chcgobearsfan3's Avatar
Car: 90 camaro RS
Re: no power
my 87 sport coupe can burn rubber just fine
Old Sep 14, 2009 | 07:57 PM
chevyfanman's Avatar
Car: 1991 camaro rs
Engine: tbi 305
Axle/Gears: its kinda low
Re: no power
my tbi 305 will keep your head back in the seat but its got 194 heads and at 80 you can give it gas and pick up the front end but its got weaker i think my dizzys going bad agian
Old Sep 15, 2009 | 01:29 PM
irish887j's Avatar
Re: no power
start with simple...dist cap, wires, plugs, & rotor...also air filter....if the engine seems and sounds like its rippin then you may have tranny or differential problems with slipping....respectively made need a fluid in the tranny/ maybe rebuild work done to it if its sliping real bad....that thing should be burning tires no prob even bone stock...sounds like tranny issues to be with the belts slipping internally
Old Sep 16, 2009 | 07:11 PM
Car: 1991 camaro rs
Engine: tbi 305
Re: no power
if it shifts fine its not his drvieline i would put an aftermarket dizzy in it cause alot of people have problems with there fire power
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
