Engine Shuts Off at Stops (redlights or stop signs)
Old Sep 14, 2009 | 02:18 PM
jake129's Avatar
Hello everyone i hope someone here can help me. I have an 89' Camaro RS V6 and the motor continues to shut off on me whenever i am stopping at redlights or stop signs randomly, it does not do it every time, but it does do it enough to be very frustrating. The car restarts right back up. What could be causing this!?!?! The guy i bought it from said a mechanic quoted him a couple hundred bucks to replace a sensor that was causing the motor to turn off...anyone know what sensor this could be or if its even the cause?
thank you in advance to anyone that can help me.
Old May 7, 2011 | 10:42 PM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
Re: Engine Shuts Off at Stops (redlights or stop signs)
could be tps... ignition system...
Old May 8, 2011 | 02:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Or the IAC valve (if you have one). My dd Falcon has been doing this same behaviour for a couple of weeks; pulling the the IAC and shooting it with carb cleaner + WD40 gets it reliable for another few days... time to replace I guess
Old May 8, 2011 | 05:25 AM
fitojdj's Avatar
also check your wiring... its useless change pieces if the problem is there...
Old May 8, 2011 | 07:36 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Sorry, I meant its time for me to change mine - just saying OP should clean his out first, see if that helps. Could be a lot of things.
Old May 8, 2011 | 08:25 AM
cliff1970's Avatar
Car: iroc z
good luck! ive been chasing this problem for months. i have replaced everything but the computer and im doing that today.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
