Swap 1989 auto,to 1992 5-speed steer column???
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
I don't really know what board to post this to,so i will try here.
I have a 92 5-speed v8.
Can I take a steering column out of an 89 automatic and swap it to my 92 5-speed?
I will also have to change out the key portion of the switch.
The key is missing from the 89,so i was just gonna use my key part of the 92 column.
Will this all work ok in my 1992 camaro?
I was not sure where to post this question so I will post it here and there,everywhere?
Thank you all for the help.
I am really getting down in the dumps over not being able to drive my stick shift.
It is my favorite car and I keep having bad luck with it.
Thanks for any info on this swap,
jd
jd
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Swap 1989 auto,to 1992 5-speed steer column???
I believe it will work not 100% but why do you want to replace the column? Theres not a lot that can go wrong with them and it might be able to be fixed rather than just replaced.
well,good question i guess.
what happened is the switch somehow got stuck on the accessory side.
and i had noticed that the column was kinda wiggly so when the mechanic
was taking it apart the bearings just fell out.
i think it was just worn out for some reason.
not really sure but the 89 was a little diffrent as far as the wires,but i think he is gonna be able to get it hooked up for me.
i hope so,cause this 84 z28 is about to gas me to death.
what makes a car that runs so good drink gas like a fish drinks water?
that's another thread i guess.
thanks for all your replies,
jd
p.s.if i have anymore problems i will ask em right here.
jd
As far as your other question your right probably another thread but since im already replying might as well. Theres really a lot of problems that can cause a car to run "good" and still use a lot of fuel. Question is how much fuel are you really using and im assuming you've checked for leaks?
evilstuie
Feb 28, 2016 03:33 PM
