Loss of power??
Old Oct 24, 2009 | 05:41 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Loss of power??
First thanks to all the people who post here it has been really helpfull.
I have a 91 z28 350 TPI and had a no start issue, fixed by reading here and my manual. I had a bad pick up coil and decided to swap the dizzy due to its age. Also put a new coil & ICM just for good measure. I got engine to operation temp and cut the it off. I unplugged the connector & started the engine, set timing @ 6* BTC cut off & plugged the connector back up then test drove. It ran smooth but had lost a bit of power woulnt even spin the tires. Reset timing to 6* BTC, now can at least spin tire but not like before. It also seems to be late shifting and has a lag at full throttle. You punch it from a dead stop and it takes a second before full power. If you are going like 35 or 40 and punch it then it also takes a little more time than usual to get spooled up. Thanks for any help i can get and when I find the solution I will post it so others can benifit as well. I a;lmost forgot when I unplugged the gray connector the book said it should generate a tbl code but all i had was the 12's the plug didnt seem to effect any thing as far as the engine running. i am quite sure i unplugged the correct one, it has a white single wire and a gray connector.
Old Oct 24, 2009 | 06:30 PM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Re: Loss of power??
The only connector that I'm familiar with that you disconnect to set timing is a brown wire with a black stripe. It breaks out of the wiring harness just above the blower motor housing.
Maybe it's different on a '91?
Old Oct 24, 2009 | 06:56 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: Loss of power??
I have the exact same problem with my car. I couldn't spin the tires from a dead stop for anything. I did the plugs, cap, rotor, checked timing etc..... and it restored a little bit of power to where i can spin them, but not as violently as i should be able to.
Do you happen to have a ticking sound from your car? I do, and its coming from my tranny. If you do, it could be something else not related to the ignition or engine.
I made the mistake looking and replacing engine parts to try to fix the problem.
Hope this helps, im just kinda rambling.
Old Oct 24, 2009 | 07:03 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
this is the only wire connector in the location that the haynes manual shows. I hope its the right one anyway
Old Oct 24, 2009 | 07:05 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
no ticking. before i replaced the ignition componants and the night before the pu coil died it would roast the rears and bark the crap out of second. Zoom Zoom>>>>>>
Old Oct 24, 2009 | 07:16 PM
Zwrench's Avatar
Engine: 5.7, None
Re: Loss of power??
Well, humor me and just take a look. If it's there we both learned something. If it's not then I learned to keep my yap shut!
Old Oct 24, 2009 | 07:33 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
sorry it took so long we have a 6 month old german shepherd and he had to do some doggie bizness. the connector that i unplugged has a white wire and goes to the coil connector closest to the firewall. there is a white wire with a stripe that is almost above the strut tower. do ya think i unplugged the wrong one??
Old Oct 24, 2009 | 08:07 PM
Zwrench's Avatar
Engine: 5.7, None
Re: Loss of power??
I have a German Shepherd too. Great dogs!
Don't worry about how long it takes to respond. Heck, I didn't expect a response at all!
Some things change from year to year but, I didn't think the EST bypass wire changed. I certainly could be wrong but, I think the wire you need to disconnect is over the blower motor housing. It should be a brown (or tan-ish) wire with a black stripe. Black connector.
The timing instructions should be on a label on the underside of the hood. If every thing's stock that is.
Do a search on EST and you may find a recent thread where someone asked the timing question.
Good luck!
Old Oct 24, 2009 | 08:17 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Loss of power??
do you have a code 42 by any chance?
Old Oct 24, 2009 | 08:30 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
i went back out there and found a light tan wire with a black tracer in a black bullet type connector i will warm it up tomorrow and giver a try. thanx for all your help. i think i did unplug the wrong wire. i was supposed to be rebuilding the steering linkage this weekend but this popped up.GM= generaly manic
Old Oct 24, 2009 | 08:31 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
no tbl codes at all
Old Oct 26, 2009 | 12:14 PM
rhall1726's Avatar
Car: 1991 Z\28
Engine: 5.7 TPI
Re: Loss of power??
found correct wire and set time and vroooom!!!!
Old Oct 26, 2009 | 07:04 PM
Zwrench's Avatar
Engine: 5.7, None
Re: Loss of power??
Great! Thanks for the update!
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
FreeSpirit
Aug 29, 2015 05:47 PM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
