My car runs like crap.
Old Oct 27, 2009 | 04:34 PM
sscamaroracer87's Avatar
Car: 87 Camaro ss
Engine: 252 V6
Transmission: Manual 5-speed
Axle/Gears: rear wheel drive and factory gears
I have a 1987 camaro 252 V6. A couple weeks ago i went through a giant puddle in it after a storm. After that it doesn't run right. The water went up to the doors and my air filters were soaked. My oil was milk. I also have no muffler on it. Every time i turn it on it idols around 350rpm. It ticks while warming up and after it has warmed up it runs at 1500rpm.Well someone told me i could have a bad o2 sensor. but on the bad side they also told me i could have a blown head gasket from all the water. because short of blowing a head i can see how that much water got into my car. but before this my car was still running like crap. it died sometimes while driving and also had and has very irregular idling. and technically it is not an SS it is a LS but my grandpa who owned it before me put the SS logo on.
Old Oct 27, 2009 | 04:43 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: My car runs like crap.
When you went throught puddle did you change the oil and then change it again after you did this. Because it might still have water lurking in the engine BAD.
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Originally Posted by sscamaroracer87
My air filters were soaked. My oil was milk. I also have no muffler on it. Every time i turn it on it idols around 350rpm. It ticks while warming up and after it has warmed up it runs at 1500rpm.
You somehow got water in your engine, thats why your OIL is milky. And that TICKING you hear is probably your Main bearings. You've spun your main bearings due to the water in the oil...........Sorry, not good.
Old Oct 27, 2009 | 04:48 PM
Car: 87 T-Top GTA
??? 87 Camaro SS ??? >>> V6 ???
I thought the models went from 1.camaro 2. camaro RS 3.camaro Z28 4. IROC-Z
Sorry, Off topic I know!
Old Oct 27, 2009 | 05:57 PM
Car: 87 Camaro ss
Engine: 252 V6
I changed the oil twice in it. and i pulled all the spark plugs out and tried starting it to get all the residual water out of there.
Old Oct 27, 2009 | 06:16 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Old Oct 27, 2009 | 10:11 PM
Car: 87 T-Top GTA
Originally Posted by V6F1R3BRD
OK, so there WASN'T any 3rd gen SS right??? (REALLY SORRY, still off topic!)
Old Oct 27, 2009 | 10:21 PM
Car: 87 T-Top GTA
I'm really sorry to tell you, but by the sounds of it, I think the damage is already done!
But look on the bright side, after you get your engine block machined at a GOOD shop, your 305 will end up being a 307 or so, and all you'll need is a set of thicker bearings and maybe new piston rings. All other engine components are reusable.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
