preheater hose is ultra hot
Old Nov 22, 2009 | 02:24 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
its a 1986 base firebird v8 305. so when i parked the car and turned the key off, i saw smoke seeping out of the hood. i checked the temperature guage and it was like 190. after i opened the hood, i saw smoke rising over the air cleaner and eventually found the source (preheater hose) the hose was so hot i couldn't touch it for more than a second without dropping it. how do i fix this problem?
Old Nov 22, 2009 | 03:53 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: preheater hose is ultra hot
Is it really a problem? The 190 degree temp is normal. And no, I wouldn't be able to put my hand on a hose that temp for very long either. But, which hose are you referring to? "Pre-Heater" doesn't exist on cars.....
Old Nov 22, 2009 | 04:22 PM
0pyders's Avatar
well i mean i don't see damage being done but still...smoke coming out of the hood worries me. its the matallic looking hose that connects from the vaccum to a part of the block on the engine. sorry i thought thats what the hose was called
[IMG]https://www.thirdgen.org/forums/Name:  diagram.jpg
Old Nov 22, 2009 | 04:46 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
You may have just spilled something on it, or maybe it was just steam from running over a puddle.
Old Nov 22, 2009 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 0pyders
i found the source (preheater hose) the hose was so hot i couldn't touch it for more than a second without dropping it.
I would be , it is connected to the exhaust manifold
Old Nov 22, 2009 | 08:32 PM
Pocket's Avatar
Car: 91 Trans Am
Thats the heat riser
Its not connected to the exhaust gasses at all. It is the tinwork surrounding the manifold, when the manifold gets hot the air around it also gets hot and rises up and is fed into the engine to accelerate warm-up
Any smoke rising from the area is from something falling on a manifold and melting
Old Nov 22, 2009 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Didn't mention anything about exh gases
Old Nov 23, 2009 | 12:26 AM
0pyders's Avatar
i think you just solved my problem. i remebmer seeing leaves on the inside. could that cause it?
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
ironbmt
Sep 27, 2015 06:00 AM
