air wont blow through ac vents
Old Nov 22, 2009 | 10:08 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
so when i turn my heat on air only blows out from the top near the windsheild. it just started doing this like 2 days ago what should i look for.
Old Nov 22, 2009 | 10:55 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: air wont blow through ac vents
vac line going to the HVAC is disconnected, it goes into the fire wall around the havc box, its a hard plastic line
Old Nov 23, 2009 | 01:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Has a check valve on line that splits vac to HVAC and the vac ball
Old Nov 23, 2009 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sticky your ear to the HAVC controls. If you hear a hiss, the switch is probably the culprit.
JamesC
Old Nov 24, 2009 | 01:05 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i fixed it. i dont have that little 3 way check valve i have a pepboys style one with no ball inside. one of the ends snapped off. thanks guys
Old Nov 24, 2009 | 02:13 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I have the same problem after removing A/C and installing the Delete pulley. Defrost heat only.
Old Nov 25, 2009 | 12:04 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
check the vacume lines under the hood
83 Crossfire TA
Jan 3, 2016 01:26 PM
64goatman
Sep 9, 2015 01:09 PM
TBRays98
Sep 6, 2015 05:05 PM
scotrans am
Sep 5, 2015 04:26 AM
90formulaVortec
Sep 3, 2015 09:26 AM
