Chevy's Best Heads For Performance!
Old Nov 28, 2009 | 11:30 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
OK everyone what are chevys best heads that give the highest performance! they need to fit a 305. No aftermarket heads! Also please list what vehicles they are found on and what year(s).
Old Nov 28, 2009 | 12:10 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Re: Chevy's Best Heads For Performance!
I was always told that my heads were excellent heads. (1984 L69 H.O.) These and the Vortec 305 heads. I think those may be found on later model trucks n such.
Old Nov 30, 2009 | 10:47 AM
killa66cam's Avatar
From what I have seen, the 305 vortec heads and the 113 aluminum corvette heads. Do a couple of searches and you will find plenty of info on both...and probably some for sale too.
Cam
Old Nov 30, 2009 | 09:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
For a 305, I'd suggest either #601 or the 5.0 Vortec heads (similar chamber to the 601/416, but with the good 5.7 Vortec intake ports).
Old Nov 30, 2009 | 10:07 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
What do you guys think about the 081 Casting 1.84/1.5 valves, (58cc combustion chamber unknown runner sizing). how do those flow and does any one have more info on them, also someone please tell me the rocker arm ratio and stud size on these 081 casting heads from an 87 LB9
Old Dec 3, 2009 | 10:05 PM
Air_Adam's Avatar
081 are essentially the same as the 416, except they use centerbolt valve covers and have the center intake bolts at 72* instead of 90*. They are a good choice.
All factory small blocks had a 3/8" rocker stud and rocker ratio of 1.5
Old Dec 4, 2009 | 01:35 AM
one92rs's Avatar
Car: SOLD!!!!!
i thought it was the 906 and 062 caasting vortec 350 heads.
Old Dec 4, 2009 | 08:35 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
so putting them on my 350 would not be a waste?
Old Dec 4, 2009 | 08:58 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i have a thread on this in the faq board that i started, you may want to look in to.
Old Dec 4, 2009 | 09:11 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Thanks i will check that out
Old Dec 5, 2009 | 01:13 AM
Air_Adam's Avatar
No. They are pretty similar to the 083s that the 350 TPI came with. Just slightly smaller chambers and valves.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
