Perimeter Bolt Valve Covers on Center Bolt Heads?
Old Dec 4, 2009 | 09:08 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I was wondering if there is any kind of adapters to put on center bolt heads so they can be able to accept perimeter bolt valve covers? any help would be awesomee!
Old Dec 4, 2009 | 09:22 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Perimeter Bolt Valve Covers on Center Bolt Heads?
http://www.summitracing.com/parts/TFS-31500811/
Old Dec 4, 2009 | 09:28 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For $110 it would be so much easier to just get the correct valve covers!
And note the description says that Narrow body rocker arms are required to clear the adapter.
But yes it does obviously exist.
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
wow didnt think they run me $110 bucks thank you for the link
Old Dec 4, 2009 | 09:30 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Yes i do have the correct valve covers on my car now but i like the way the perimeter bolts look, also it says narrow body rocker arms if im installing roller rockers will they fit
Old Dec 4, 2009 | 09:43 AM
battman's Avatar
a little better deal:
http://cgi.ebay.com/ebaymotors/Trick...item4a9cbf78df
Old Dec 4, 2009 | 10:30 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Originally Posted by battman
Thanks for everythin, could i get explained the whole narrow rocker arm thing
Old Dec 4, 2009 | 10:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can't use full roller rocker arms. They are typically too fat.
You like the way perimeter bolt covers look? I'll admit that I'm a function-over-form guy, but I just can't see thinking perimeter bolt covers look better. And I'd never sacrifice better function for better looks, let alone better function for worse (in my opinion) looks.
Old Dec 4, 2009 | 11:10 AM
battman's Avatar
I'm not sure with the adapters but I am currently running full bodied full roller aluminum 1.5 rockers under a set of standard height cast aluminum center-bolt valve covers with no problems
Old Dec 4, 2009 | 11:25 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Well I am also a function over form type of person thats why im not going to buy these i will admit that i do like the look of perimeter bolt covers better but for$109 ill keep the centerbolts $109 could be put towards the set of roller rockers id like to get.
Old Dec 4, 2009 | 12:05 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I put a set of those adapter's on a GTA, they work well, no leaks. I will say this though, the side bolt valve covers a hell of alot easier to get on and off with out taking alot of **** apart compared to the centerbolts.
Old Dec 4, 2009 | 12:11 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
i dont think i understand, with centerbolts you remove those 4 easy to get to bolts and pull them off its not hard
Old Dec 4, 2009 | 04:05 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Perimeter bolt valve covers......Leak, every brand of engine with those nasty things leak oil all over the place. I'm glad GM changed!!!
Old Dec 4, 2009 | 04:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Couldn't keep gaskets sealed on my TFS perimeter bolt heads.Different brands of gasket , glued gasket to cover; the crankcase pressure of the 383 would blow the gasket out somewhere.
New heads ( same TFS ) are centerbolt ; not a leak in sight
Old Dec 4, 2009 | 05:36 PM
Stephen's Avatar
Car: 87 GTA
My 327 in my 68 Camaro never leaked one bit....
Old Dec 4, 2009 | 06:21 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Did it have stock valve covers? If so you must really know how to put them on correctly, over-torque the screws just a little " like most people tend to do" and you bend the covers, then get a leak. The more solid cast covers did ok, but still not near as good as center bolts.
Old Dec 7, 2009 | 08:06 AM
Have you ever pulled the valve covers with the engine fully assembled in a 3rd gen?
On the driver side the alternator stud where you connect the large wire to the batt hits the lip on the centerbolts and you cant shift them forward/backward because of the supports on in the center go all the way down between the rockers. The passenger side, hahahaha, heater hoses air injection hoses, wiring harness the a/c compressor...tons of stuff in the way. With perimeter covers, yes it does take an extra minute or two to get the bolts out, but you can have to covers off in like 5 minutes.
We haven't had any problems with leaks on the side bolts. Using the Fel Pro rubber gaskets and the valve cover spreader bars. these beauties right here, http://www.summitracing.com/parts/TRD-4993/?image=large if anyone doesn' know what I am talking about
Old Dec 7, 2009 | 05:16 PM
Stephen's Avatar
Car: 87 GTA
On the driver side the alternator stud where you connect the large wire to the batt hits the lip on the centerbolts and you cant shift them forward/backward because of the supports on in the center go all the way down between the rockers. The passenger side, hahahaha, heater hoses air injection hoses, wiring harness the a/c compressor...tons of stuff in the way. With perimeter covers, yes it does take an extra minute or two to get the bolts out, but you can have to covers off in like 5 minutes........
Sounds like a SERPENTINE BELT problem, not a valve cover problem. My 87 has center bolt valve covers, but the alternator is on the passenger side. All those air injection hoses are in the way, but that is an emissions parts problem, nothing to do with the valve cover style. They'd still be in the way, regardless of which valve cover was under them.
Old Dec 7, 2009 | 07:51 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You could get a set of carbon fiber center bot value covers. They run about $300.
Old Dec 7, 2009 | 10:04 PM
Car: 1992 RS
Engine: Carbed 350
Sounds like a SERPENTINE BELT problem, not a valve cover problem. .
It is. My 1992 had serpentine and had the same issue. Getting the valve cover off was always a PITA, then when I swapped to the 350, I installed a nice set of chrome perimeter covers on - but still had the same issue. In fact, with the serpentine alternator on the driver side, the new chrome valve covers would touch that bolt on the alternator - so I had to remove the alternator and bang a ding in the corner of the valve cover to just have enough space there so that the bolt didn't touch, then I put a rubber vacuum cap on the bolt to keep the juice from arcing across tothe valve cover.
I have since swapped out for the 1/2 serp 1/2 v-belt brackets from the earlier IROCS, removed A/C, and relocated alt to pass side - problem solved for me.
FYI - the perimeter covers won't help you any, and may be worse (like mine were). It's a serpentine bracket/alternator issue.
evilstuie
Jan 9, 2020 08:29 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
