Crank underdrive pulley only, would it help?
Old Dec 8, 2009 | 07:04 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I ended up with a crank underdrive pulley, but not the alternator or water pump pulley. Would it be worth changing just the crank pulley?
It does look better than the stock pulley and weighs less. I dont think it will make much of a difference. What do you guys think.
Old Dec 8, 2009 | 07:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Crank underdrive pulley only, would it help?
It will help. A full set claims 10-15hp upgrade over stock pullys so...7-8hp? You'll have to get a new belt too I believe because of the size difference.
Old Dec 10, 2009 | 03:33 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if this is your daily driver, you're may run into charging issues with the alternator and possibly a hotter running setup since you've slowed down the rotation of everything else. While you may pick up some lost hp, you may be hurting a few other things in the process. If its just a weekend warrior, go for it.
Old Dec 10, 2009 | 04:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I did this and the engine free rev'd better. Not sure how much if any power i gained, track didnt show much, half tenth or so but i did experience charging issues with no alternator pulley.
AFter i went to the smaller alternator pulley i had no problems
Old Dec 10, 2009 | 05:11 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
agree! i have the march underdrive pulley on my crank, way lighter/smaller than the stock. It was a 2 peice set (crank/alt) but i found that the alt pulley was too large and it was wrong lol it was a 6 rib belt when the crank was a 5rib belt. I kept the crank and used it but i found a smaller than stock alt pulley and it works fine, charging isnt bad unless im at a stop light with my lights on and my radio etc even then its still like 12V...
Old Dec 11, 2009 | 07:09 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well its not a DD, just on occasions and to the track and back.
I might try it and see what happens.
I am running a a/c delete pulley and no smog pump. I will have to measure for new belt.
Old Dec 11, 2009 | 02:02 PM
Guest
Guest
Posts: n/a
The purpose of the alternator pulleys in those kits is to make the alternator spin faster to make up for the loss in speed from the smaller crank pulley. So you're going to make more HP with just the crank pulley than with both pieces, but less charging capability at the same time. I dont know what the water pump pulleys are so I cant comment but if they're smaller than stock then its the same story there.
Old Dec 11, 2009 | 02:13 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Same here. Scored an underdrive crank pulley at a swap meet for peanuts. Then took my alt pulley with me to the junk yard and went through this bin of altenators until I found one that had the same inner shaft size and was smaller in diameter. Took a WHILE but I found one. Junk yard operator thought I as crazy out there with a mic, measuring all these pulleys.
Old Dec 14, 2009 | 07:22 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Ok guys, on the topic of changing the alternator pulley. What if I keep the stock crank pulley and changed the alternator pulley to spin faster. Would this be a good idea?
This is just in theory, would it help a stock charging system?
Im not having any charging problems, but it might be a solution for someone else. Whats your thoughts?
Old Dec 14, 2009 | 09:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I think there would be a point where extra spin speed on the alternator would not produce anymore current/amps/etc. there is a speed in which the alternator needs to spin to charge the battery and run the motor at idle and the ratio between crank pulley size and alternator pulley size achieves this. Underdrives are smaller in diameter but maintain that ratio to have good charging at idle. If you go faster i dont think it will help since the alternator can only put out so much power.
I'd go with an aluminum crank pulley and the alternator pulley to free up rotating mass and let that engine free rev faster. It works and does give a small power gain
Old Dec 14, 2009 | 11:46 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks Orr, I thought the the stock alternator would have its limits.
RS Reaper
Oct 17, 2018 07:52 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
