Please help me get my car running!
Old Dec 13, 2009 | 02:00 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
My car's fuel pressure is 29lbs. with key on. The car won't run. I can sometimes get it to start, but then it stalls about 3 seconds later. If i give it ANY throttle it will immediately stall. The fuel pump and ECM are new. fuel filter maybe has 5K miles on it in the last 3 years since it was replaced. Any ideas?
Old Dec 13, 2009 | 03:25 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Please help me get my car running!
i had a similar problem, it was the air gap between the pickup coil and reluctor wheel in the distrubutor was too large. if that is your problem your spark plugs will be fouled and will need to be replaced
Old Dec 13, 2009 | 06:36 PM
trueburton's Avatar
how would that give me low fuel pressure?
Old Dec 13, 2009 | 09:09 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If you have 29psi with the key on and engine off it will drop to about 20psi when full engine vacuum is applied to the FPR at idle. Before starting the engine remove the vacuum line to the FPR and plug it. Then see if the engine will idle, or stays running longer.
Remember just because something is new doesn't mean it can't be defective, but assuming it's a good fuel pump and electrical is good (no excessive voltage drop) give the following some thought.
The symptoms of a bad fuel pressure regulator include:
Lack of fuel pressure, excessive fuel pressure, black smoke and rich engine running condition, instant drop of fuel pressure once the vehicle has been turned off, delay building sufficient fuel pressure.
Don't forget to replace the spark plugs once you get the pressure back up because they're probably fouled by now.
It's also possible you're leaking fuel back into the tank resulting in a pressure loss.
Old Dec 13, 2009 | 09:55 PM
ok. so its a tpi. see if there is a rubber section of fuel line somewhere in the fuel return. completely pinch the hose, turn the key on and see if the pressure goes up to spec. if so its likely a stuck-open regulator. if not make sure you have 12.5 volts at the fuel pump, if you do it has to be a bad/wrong fuel pump. the distributor does suppy a cam signal to the ecm
Old Dec 13, 2009 | 10:22 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Originally Posted by skirkland1980
... the distributor does suppy a cam signal to the ecm
Distributor reference signal not needed to start engine only for ECM to control, but not below 400rpm. in other words engine must start before ECM can control the engine.
Old Dec 14, 2009 | 05:16 PM
trueburton's Avatar
thanks alot guys, as i turns out i don't think the pump has been replaced. I had everything torn out because we thought the pump was bad when it turned out to be ok. this was about 6 months ago. Man i'm pissed i didn't replace it back then. Think i might try the access hatch method this time though. First i'll check the other things in regard to the regulator. thanks i'll keep u informed.
Old Dec 16, 2009 | 06:53 PM
trueburton's Avatar
ok so i pinched off the return line and it did not change anything. Would it pretty much HAVE to be the fuel pump at this point?
Old Jan 14, 2010 | 06:10 PM
trueburton's Avatar
Update
Today i hooked up my Fuel pressure gauge to the output end of my fuel filter. What should the pressure be at this point?
Old Jan 14, 2010 | 11:24 PM
Re: Update
38-48 psi
Old Jan 15, 2010 | 03:41 PM
trueburton's Avatar
Re: Update
yeah i have like 30 after the filter so that would eliminate the possibility for the regulator being bad right? I also checked my voltage at the pump. The purple wire has 11V and i got nothing at the gray wire. What supplies the gray wire with voltage?
Old Jan 15, 2010 | 05:10 PM
Re: Update
i think there should be 4 wires to the tank. pump power, ground, and two wires for the fuel level sensor. 11 volts is only ok if the battery is 11 volts. you should be within 1 volt of battery voltage. i'm not so sure you can get that pump out through the hatch unless you plan on cutting a big hole in your car
Old Jan 15, 2010 | 07:09 PM
trueburton's Avatar
Re: Update
no there are definatly only three wires. i need to know what the gray wire does, cause i have no power to it.
Old Jan 15, 2010 | 09:14 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: Update
Psi at the pump should be higher than rail psi as there's still several feet of tubing plus the fittings, filter and regulator.
Wiring:
My three wires are:
Tan - pump 12V from fuel pump relay
Pink - fuel gauge (voltage depends on fuel level; ignition must be on)
Black - ground for both pump and level sensor.
Old Jan 16, 2010 | 10:34 AM
trueburton's Avatar
should both wires have constant power?
Old Jan 16, 2010 | 01:06 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
If the key is on and engine off the fuel sender will have voltage, and the pump will only have voltage while priming.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
