car will take a few to shut off
Old Dec 31, 2009 | 01:13 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
ok go my motor in my l69 and it runs awsome and sounds good.. juts when i shut it off it takes a few to die. the key will be off and it takes like 5-10 sec to shut off any ideas??
Old Dec 31, 2009 | 01:16 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: car will take a few to shut off
look up something called "dieseling" thats what its doing.
i would explain more but theres alot that can cause it.
Old Dec 31, 2009 | 01:24 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
no its not "dieseling" it runs fine its like the key is not killing the car... i think the wiring is wrong to the alt and its feeding the hei not killing the car... no the car runs good and the carb is tuned good and timing is dead on. or the key switch it self is bad
Old Dec 31, 2009 | 01:35 AM
ShMaCk2004's Avatar
dieseling is when the car continues to run after you cut off the ignition.
http://en.wikipedia.org/wiki/Dieseling
Old Dec 31, 2009 | 01:38 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
i know what "dieseling" is and its not that..... it runs the same with the key on as it does with the key off.. it just takes a few to shut off almost like when you turn your key off and it dies rightaway mine stays running for a few more secs
Old Dec 31, 2009 | 01:45 AM
ShMaCk2004's Avatar
yes and that is dieseling...unless its still sparking
Old Dec 31, 2009 | 01:49 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
yes it is still sparking and running like it does regularly. still hit the gas and it raps out.
Old Dec 31, 2009 | 01:55 AM
ShMaCk2004's Avatar
you sure its sparking?
Old Dec 31, 2009 | 01:57 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Cool Down Timer???
Old Dec 31, 2009 | 02:04 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
i turn the key off and i can rap it out and it runs like a it usually does..
lol on the cool down timier no not yet still workin on the turbo's
i think its the switch it self not cutting the power off and yes i am sure its still sparking
Old Dec 31, 2009 | 12:26 PM
ShMaCk2004's Avatar
then its an electrical issue try the ignition switch
Old Dec 31, 2009 | 12:34 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
ignition switch would be my guess as well.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
