combo opinions wanted
Old Jan 1, 2010 | 06:03 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I have been researching options and I have narrowed it down to this,opinions please.
I have, 357 sbc,882 heads,Herbert flat tappet 235/245@.05,.500/.500,108lsa.
Th350/approx.3000 stall,12 bolt 3:73 gear.Holley 750 D.P,Professional Products dual-plane air-gap intake.Long -tube headers/2.5" dual mufflers.
New combo thoughts:
RHS pro-action, comp.products pn-RHS12025K3,200cc-64cc,angle plug
Comp Cams 280ar,Comp pn-12-702-8,236/236@.05,550/.550,110 LCA-106ICL
OR
Comp xr268r,Comp pn-12-769-8,230/236@.05,.552/.564,110 LCA-106ICL
This is a drag only car.
Good,bad,ugly,any other opinions?Anymore info needed?
Thanks for your time
Mike T
Old Jan 3, 2010 | 06:11 AM
Quinny's Avatar
Re: combo opinions wanted
Seems a little tame for a dedicated drag car - I would probably be looking at some better heads - Dart Iron Eagles are cheap and flow well, go to a solid roller cam somewhere in the mid 240s or low 250s duration, around .600" lift. Also go single plane, and 3500-4000 stall with transbrake for hard launches.
This means that the engine needs to be able to take 6500rpm (at least) reliably, and the box will need to be built to cope too.
What sort of times are you looking for?
Old Jan 3, 2010 | 09:56 AM
Car: 92rs
Transmission: 350
This is a stock rebuild bottom end so I am not trying to go past 6200 rpm or so,reason I chose a cam in the lower rpm range.
I am going solid roller.
I would like to see an 11.90 at least,I have been 12.76@105 with present combo so I think it can be done easily with new combo.
Mike T
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
nuggie
Aug 25, 2015 01:27 PM
