Coolant Problem-Easy Fix
Old Jan 3, 2010 | 10:04 PM
Allamericantc's Avatar
Car: 87 TA
Engine: 355
Guys
I just swapped in a 350 into my 87 TA. I put in coolant tonight and noticed it was running out of the drivers side head. Is this a drain hole and should I have a plug here? Knock is on the opposite side. Its the L98 block FYI
Thanks for any help!
Old Jan 3, 2010 | 10:51 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Coolant Problem-Easy Fix
post a picture of the leak.
Old Jan 4, 2010 | 12:49 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Post a photo of where the coolant is leaking from. There are more than a few places coolant can appear.
Old Jan 4, 2010 | 04:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
There is a coolant temp sensor in the drivers head for the gauge.
Old Jan 4, 2010 | 06:58 PM
Car: 87 TA
Engine: 355
I will post pics when I get over to the car tomorrow. In Twin_Turbo's thread here, look in the 154th post, second picture down. Its the same spot where he has that bolt (in the head). Here is the link:
https://www.thirdgen.org/forums/memb...my-87-a-4.html
Again. Thanks for all of the help!
Old Jan 4, 2010 | 07:44 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Old Jan 4, 2010 | 07:46 PM
Car: 87 TA
Engine: 355
Alright, just wanted to check. Any idea how much they run? and what wire connector goes to it?
Old Jan 5, 2010 | 07:46 PM
Car: 87 TA
Engine: 355
OK. I put in the coolant temp sensor. Now I cannot find the connector that goes into it. Anyone have a pic of where the connector is coming from? Also, anyone have a pic of where the temp sensor from the bottom of the intake goes into?
I appreciate the help so far.
Old Jan 6, 2010 | 04:15 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The connector for the head is in the same loom as the O2 sensor connector.
The IAT connector comes out of the large loom that runs behind the engine from side to side. Sorry no pics. My car's not here.
Old Jan 6, 2010 | 01:38 PM
Car: 87 TA
Engine: 355
Thanks. I'll take a look
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
89 formula TPI
Oct 6, 2015 08:40 PM
FormulasOnly
Sep 10, 2015 09:07 PM
