Eagle ESP cranks, better than stock?
Old Jan 8, 2010 | 12:02 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I was looking at getting one of these cranks for a decent price and upgrading my rods too. I am shooting for 570-580hp at the crank, shifting at 7k. Pistons are KB 147's. I was wondering if it be worth upgrading the crank. I have heard different stories about how much stock parts can take.
The ESP cranks are cast steel. What are "stock" crankshafts made out of?
Thanks for any input.
Jason
Old Jan 8, 2010 | 12:06 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Eagle ESP cranks, better than stock?
Originally Posted by LilJayV10
I am shooting for 570-580hp at the crank, shifting at 7k. What are "stock" crankshafts made out of?
Cast iron in most, nodular iron in some.
Forged steel in Hi-Po apps (ZZ4)
If you are looking at those #'s ;better invest in a forged crank.
Cast steel cranks are rated 450-500Hp at lower revs depending on who you believe
Some background reading
http://www.carcraft.com/techarticles..._to/index.html
Old Jan 8, 2010 | 01:50 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
your stock crank will out perform your tires, axles, wheel studs, u-joints, and driving ability. i'm pushing 600hp through mine and broke lots of "other" parts. sometimes lighter parts can be better even though it's not stronger... something to think about...
Old Jan 8, 2010 | 02:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by skirkland1980
your stock crank will out perform your ......... and driving ability..
Stock cast or stock forged?
Big difference
Old Jan 8, 2010 | 04:31 AM
Twin_Turbo's Avatar
A stock cast crank goes a surprisingly long way as long as you don't rev the snot out of it.
Old Jan 18, 2010 | 01:34 AM
LilJayV10's Avatar
Engine: 406 Roller
I "think" i will be ok with the stock crank and KB pistons, I think they are suppose to be lighter. The rods are the only thing I am worried about. But people go stupid fast on stock parts.
I ended up going with a bigger cam than I originally planned. I will be shifting at 7k. Yikes!
355tpipickup
Aug 27, 2015 08:13 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Thirim
Aug 13, 2015 03:09 PM
