Camaro won't start
Old Jan 8, 2010 | 09:38 AM
THEGunboundGod's Avatar
Car: 1986 Z28
Axle/Gears: 4.11
Camaro won't start
305 Carburated
Had a new $400 starter put in during the summer. New clutch starter switch. Battery is fine, terminals clean. Fuel squirts when I hit the gas pedal. Lights, radio, etc. work, there's a clicking I can hear when I turn the key, sounds like it's coming from under the car, I think it's the starter doing it's thing. Tried jump starting, doesn't work. Anyone have any ideas?
Old Jan 8, 2010 | 10:18 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Camaro won't start
is that starter gold plated or was that with labor included
Old Jan 8, 2010 | 02:31 PM
Car: 1986 Z28
Axle/Gears: 4.11
I don't know what gold plated is but mechanics put it in.
Old Jan 8, 2010 | 08:46 PM
Richwiz1's Avatar
Gold plating means it is plated with gold like a watch or necklace. The only things I can think of right now are 1. starter needs shimmed 2. bad solinoid or your vats system. Hope this helps.
Old Jan 8, 2010 | 09:46 PM
Car: 1986 Z28
Axle/Gears: 4.11
Is vats a computer thing? Cause I don't have any computer/chips in my car.
Old Jan 10, 2010 | 05:42 PM
Richwiz1's Avatar
vats stands for vehical anti theft system I dont know when they started putting them in gm cars if your key has a computer chip in it you have vats there is a thread on here somewhere on it do a search u can bypass it or take it back to who installed the starter. Was it working when u left the shop?
Old Jan 10, 2010 | 07:39 PM
Car: 1986 Z28
Axle/Gears: 4.11
There's no vats. The car started up like three times, the engine was warm and I started it again to bring it to my friend's house and it wouldn't go.
Old Jan 11, 2010 | 09:39 AM
jamon8's Avatar
Engine: 350 tpi
you may need a heat shield on your starter selinoid
does this happen mainly when the car is warm
Old Jan 11, 2010 | 02:18 PM
Car: 1986 Z28
Axle/Gears: 4.11
I've had it towed 4 times I think, once it over heated, the starter died, the clutch starter switch need replacing, and now this. I think two of those times were cold nights. I don't drive it in the winter either, I just got it back for rust removal on the bottom of the doors, guy told me I'd get it before thanksgiving and I got it back a few days ago.
Old Jan 11, 2010 | 04:01 PM
SupremeC84's Avatar
I am having same prob's with my I-rocc I replaced starter,new battery,new distributor cap and it still does not fire my starter is cranking but the engine does not fire up all these problems occured when I did drive for a couple weeks and the weather got really cold. if you figure some then out let me know
Old Jan 11, 2010 | 04:13 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Could be ignition module.
Old Jan 11, 2010 | 04:20 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
+1.
Starter - 150
Labor of 2 screws -250?
Somethings wrong. It's 2 bolts, few wires and a little wiggling. I did mine in 25 mins... Took longer to actually jack the thing up and get all tools needed hahaha.
Old Jan 12, 2010 | 12:01 AM
Richwiz1's Avatar
Check the wiring to the solenoid make sure none are broken or burnt.If that dont work since its standard shift put it in gear and rock it back and forth maybe jammed in between two teeth on flywheel I used to have to hit mine with a sledgehammer sounds stupid but it worked also check warranty maybe bad starter or solenoid or bad clutch safety switch.
Old Jan 12, 2010 | 08:56 AM
jamon8's Avatar
Engine: 350 tpi
Originally Posted by JTNKTZ
+1.
Starter - 150
150 for a starter
it better be a mini
Old Jan 12, 2010 | 02:24 PM
Car: 1986 Z28
Axle/Gears: 4.11
it was the $400 starter that was put in the summer, fortunately it's still under warranty.
Old Jan 12, 2010 | 05:23 PM
Richwiz1's Avatar
Then I would take it back to the mechanic and try not to let him recharge u for labor. Is it a tilton starter or what if not once he fixed it I would find a new mech thats way to much for a starter.
Old Jan 12, 2010 | 06:18 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
I paid maybe 55 bucks for my starter( Re-Manufactured/no problems over a year old now) and put in my self. 400bucks? you got screwed. Sorry to be so blunt, but weather or not it was still under warrenty, you got screwed!
Old Jan 12, 2010 | 09:16 PM
Car: 1986 Z28
Axle/Gears: 4.11
They said because it wasn't the original engine they could only get that starter, a high performance $400 one. It seems like the they screwed me, but they've been wicked nice before. A few times they spent hours of labor trying to one thing on my car, and realizing they were wasting their time taking apart the cruise control or something. They eventually fixed it and charged me nothing. They've charged my mom nothing too sometimes, even though they've had every right to.
Old Jan 13, 2010 | 05:03 PM
Fair enough...... The important thing is that your got beast runnin' good. I love these cars
Old Jan 14, 2010 | 03:26 PM
Car: 1986 Z28
Axle/Gears: 4.11
Yay they charged me $0 but I had it inspected and I need a new rear right tire. Unfortunately the same model doesn't exist, so I have to get rubber that doens't say goodyear.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
