v6 running weird help please!!!!
Old Jan 13, 2010 | 03:35 PM
kurt5153's Avatar
Hey guys I got a 89 camaro with a 2.8, my problam is at idle it back fires n the idle bounces, also sounds like a miss fire. I'm guessing it has a vaccum leak or the plug wires crossed some there. I was woundering if you guys cam steer me in the right way n if possable provide me with a vaccum diagram also whitch plug wire goes where. Thxs
Old Jan 13, 2010 | 06:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
By "bounces", do you mean the engine sounds like the idle is jumping around, or the tach needle drops when the engine seems to miss? If the latter, you might have an ignition control issue (i.e., not related to spark plugs or wires).
On the FAQ forum there is a thread with information about vacuum diagrams. Yours should be posted there.
Old Jan 13, 2010 | 08:15 PM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Re: v6 running weird help please!!!!
try setting your timing.
Old Jan 13, 2010 | 09:55 PM
kurt5153's Avatar
Five7kid-It sounds like the motor revs then will goback down on idle, what do you mean by latter?
marekdennhardt- how do you do that, I know you turn the distribuater n I'm guessing you need a timming light.
Old Jan 13, 2010 | 10:13 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
You need a timing light. They aren't expensive ($30). Loosen distributor cap, unplug the single wire near the top of the passenger side firewall (brown and black stripe I think), clip timing light onto #1 cylinder wire (passenger front of engine), start car, set timing to 10 degrees btdc, turn car off, plug the wire in you unplugged on the firewall, take off timer, start car, test and rev, tighten cap. make sure you don't adjust it after timing by accident.
also check for vacuum leaks too, I found mine on the drivers side of the engine near the back, and on the top where three hoses connect at a "t".
Good luck
Old Jan 13, 2010 | 10:14 PM
kurt5153's Avatar
K sweet, I just found a vaccum hoose but it was a screw in it ? N no place by it to plug it in. N I'm still having truble finding a vaccum diagram
Old Jan 14, 2010 | 12:06 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
You'll probably need a timing chain too if you don't know when it was replaced last. My 2.8 had a really sloppy idle until I replaced it, they're really high wear parts and my manual says it needs to be replaced every 30k miles!
Old Jan 14, 2010 | 12:19 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Wow, how much are those and where did you get your from?
Old Jan 14, 2010 | 02:32 PM
kurt5153's Avatar
Really, cause it was fint then just strated running weird.
Old Jan 17, 2010 | 01:39 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
did you find anything that helped?
Cleotiz
Jan 6, 2018 08:56 PM
maroe624
Apr 16, 2017 08:29 AM
sreZ28
Aug 14, 2015 07:48 PM
novaderrik
Aug 10, 2015 12:44 PM
gwade12
Aug 8, 2015 08:17 AM
