Looking for 140 GPH fuel filter, any advice?
Old Jan 18, 2010 | 06:35 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I'm trying to decide on a fuel filter setup to go with dual Walbro 392 inline fuel pumps, run in parallel. They flow roughly 70 GPH (255LPH) each.
There is no pump in the tank. It is gravity fed and everything (pumps and filter(s)) will be lower than the tank. The high pressure side will operate at about 20 PSI.
I would like to put a good filter on the low pressure (inlet) side so that the pumps will be protected.
I am looking at this (rated @ 130GPH):
http://www.summitracing.com/parts/SUM-230105/
But I suspect that the small surface area would mean frequent cleaning and possible starvation with only 1 tank of cruddy gas.
I like this one:
http://www.summitracing.com/parts/FRM-HPG1/
But it is only rated at 90 GPH so I would have to run 2 in parallel, it is also bulky so getting 2 on the inlet side of the pumps would be difficult.
I don't know how either of these would work on the suction side of the pumps.
Anyone have any suggestions? Have you used one of these? Have you used something else that you would recommend?
Thanks,
Old Jan 18, 2010 | 06:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Looking for 140 GPH fuel filter, any advice?
these ones apparently flow 600 gph. I have a almost new one in the garage sitting on the shelf....
http://www.summitracing.com/parts/SOF-200-201408/
Old Jan 18, 2010 | 06:57 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
That is definately some healthy flow, but I suspect it (like the first one I listed) has a small internal surface area and would clog easily.
Do you have a picture of the filter element?
Old Jan 18, 2010 | 07:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no but i can get you one. Give me a couple minutes
Old Jan 18, 2010 | 07:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ASAIK, that summit filter you posted only has a little round, flat screen filter, similar to a Russel i had a long time ago.
here's the system 1
sorry, kinda blurry, the camera really blows up close
Old Jan 18, 2010 | 07:25 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
No, those pictures are fine. They tell me what I need to know. Thanks.
You are right the summit filter is a tiny disk. Here it is:
http://www.summitracing.com/parts/SUM-230110/?rtype=10
That System 1 filter looks small (1.5" diameter x 1.5" tall?) but it also looks like it would have 10 or 20 times the surface area of the Summit filter.
That is a stainless steel mesh filter isn't it? I don't see replacement elements on Summits web site, do you know if/where they are available?
Also, what do you think about using it on the suction side?
Old Jan 18, 2010 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
since its stainless, i believe its a lifetime filter, just hose it off and slap it back in? I was using it on the suction side of a mechanical setup, no issues, but im not sure if the 10gpm rating is pressure or suction. Cant be worse than the stock sock filters
Old Jan 18, 2010 | 09:36 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
OK I'm leaning toward the System 1 filter now. I may order one tomorrow.
Old Jan 19, 2010 | 07:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if you are interested, and its the right size for what you are doing, i can sell you mine really cheap. It only has a couple hours of use, some nicks on the wrench flats from taking it apart a couple times.
its 8an inlet/outlet
Old Jan 19, 2010 | 07:21 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
I would, but I ordered a new one this morning.
But...How cheap is REALLY cheap? I suppose a spare couldn't hurt.
Old Jan 20, 2010 | 06:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
25 bux shipped?
Old Jan 20, 2010 | 07:07 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
That is a good price. My new one is supposed to arrive tomorrow. If the new one looks like it will work, (and I expect it will) I'll go ahead and take yours also.
Old Jan 21, 2010 | 06:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ok, if you want it let me know, send me a pm
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
