rear main seal
Old Jan 24, 2010 | 04:08 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
rear main seal
I know this is going to sound stupid but does anyone have a pic of how a one piece rear main seal is supposed to look when its installed, or instructions on how to install one? I'm rebuilding a vortec block, first time rebuilding a motor, and all the literature I have on rebuilding chevy's is for two piece rear mains, and the gasket set has no info on how it goes on. Thanks for the help.
Old Jan 24, 2010 | 07:51 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: rear main seal
Bolt the seal housing to the rear of the block with new paper gasket. I hold the seal against the crank with one hand and use a pick or transmition seal tool to get the lip started with the other. after the seal is started you can use a drift to drive it on in.
Old Jan 25, 2010 | 08:45 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: rear main seal
Make sure you install the seal with the lip pointing in the right direction.
Old Jan 25, 2010 | 10:19 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: rear main seal
FASTS=FASTEST
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
