So I've got some 67cc S/R Torquer heads..
Old 01-28-2010, 08:21 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
..and I've got a couple questions.
The heads are set up for a flat tappet cam and I've got a carbed 89 L98 with the stock roller cam. What do I need to make them work? New lifters?
And as far as bolting them on with the stock cam, how much power would be gained?
I'm not against installing a new cam but I'd like to know what it'd do without one.
Old 01-28-2010, 09:02 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You either need to drill out the pushrod holes, or get non-self-aligning rockers.
With a stock L98 cam, the World springs aren't going to have any problems.
(BTW, you can't run flat lifters on a roller cam.)
Old 01-28-2010, 09:38 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: So I've got some 67cc S/R Torquer heads..
Ok so new rockers and lifters and it's a swap.
What will this do for me in the power department with the stock cam?
Old 01-29-2010, 05:45 PM
five7kid's Avatar
Engine: LS1/LQ4
Why do you think you need new lifters?
Old 01-29-2010, 06:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The heads don't care whether it's a flat or roller cam.
Old 01-30-2010, 11:08 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
I have no idea. Still learning. I see now that I don't.
I was referring to what valve train changes had to be made. Heads are on an early 80's 350.
Old 01-30-2010, 02:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, but there are no valvetrain changes needed on the heads.
Old 01-30-2010, 04:45 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
My bad dude. Obviously I have alot of learning to do or I wouldn't be asking in the first place.
Old 01-30-2010, 06:13 PM
five7kid's Avatar
Engine: LS1/LQ4
No changes except what I mentioned in my first response.
Old 01-30-2010, 11:55 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Ok, thanks, I've got it all figured out now and I already have the rockers I need.
I just realized though these are not the actual Torquers. They are simply the S/R heads.
http://www.jegs.com/i/World+Products...610-1/10002/-1
There are the specs.
Now I'm just wondering if they're any better than stock L98 heads. I would think so but I really don't know. I just need to know what kind of gains the swap would be worth before I actually get into making the swap.
Thanks for anyone who helps.
86z89iroc
10-05-2015 01:04 PM
TexasMaro
09-15-2015 06:50 PM
1986CamaroIROC-Z
Aftermarket Product Review
11-08-2001 10:53 PM
MattW
07-18-2001 12:13 AM
86Z
Carburetors
06-10-2001 08:57 PM
Quick Reply: So I've got some 67cc S/R Torquer heads..
