what cam do i need?
Old Jan 28, 2010 | 10:08 PM
luke89's Avatar
Car: 96 jeep cherokee, 89 camaro
Engine: 355
Transmission: t5
Axle/Gears: eaton locker/3:73 gears
what cam do i need?
hi, i have a 1987 350 with stock roller cam. what cam do i need to get i looked and all the cams are like 400 that are roller. is there any cheaper ones for that motor? i want just a mild cam for street use.
Old Jan 28, 2010 | 10:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: what cam do i need?
roller cams are expensive, you might find a used cam on ebay or on forums here. maybe a used lt1 cam would work good in your car if it's close to stock.
Old Jan 28, 2010 | 10:26 PM
luke89's Avatar
Engine: 355
Transmission: t5
am i able to use a flat tappet cam if i get new lifters? because i really dont have all that much money and just wanna get this car going but id like to throw a cam in it.
Old Jan 28, 2010 | 10:32 PM
Engine: L98 494hp
they might make a taller flat tappet, but not likely. The boss that holds the lifter I believe is taller....besides going flat tappet would be a step backwards. You wouldn't feel that much power gain from doing a small cam swap anyway, and maybe nothing at all. not worth the waste of money, you're better off to spend the money on something else, like exhaust. Furthermore the cam has to be computer compatible....and that would be just a bad idea to go flat tappet. spend money on something that will make a difference.
Old Jan 28, 2010 | 10:49 PM
luke89's Avatar
Engine: 355
Transmission: t5
im gunna be running a carb on it so i wouldnt have to worry about computer. i just wanna throw a cam in now while i have the engine apart. but maybe it doesnt have a roller in it now. i was researching and it looks like the roller ones had a plate in the center going to the lifters. mine doesnt. just the mounts for it. is it not a roller?
Old Jan 28, 2010 | 11:13 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Your engine must have come from a truck. Starting in 1986 some truck engines did not have roller cams but cars did. Trucks engines got them later. Either way you are set.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
