burning wires
Old Jan 31, 2010 | 11:34 PM
89native's Avatar
Car: 1989 firebird
Engine: 305ci efi 48k miles
burning wires
got new spark plug wires, went from stock to 8.5. they don't fit on the stock looms so like a idiot i just set them away from the exhaust manifold and they got burned
any ideas on looms and wires i can use i dont have headers yet and don't plan on wrapping the manifold with tape till i get some
Old Feb 1, 2010 | 12:13 AM
Drew's Avatar
Re: burning wires
The hill-billy technique is zip ties.
Or you can hit www.summit.com and search for "spark plug wire looms" and browse the 9 pages of results for something you like.
Old Feb 1, 2010 | 08:16 AM
Pocket's Avatar
Car: 91 Trans Am
Re: burning wires
Ive had good luck with these
Spectre brand, $12 or so off ebay
Old Feb 1, 2010 | 09:22 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: burning wires
I second Pocket's idea. I use them as well and they work nice and look fairly good too. They deffinetly keep them in place and give them the appropriate spacing to prevent misfiring issues due to induced voltages from the other wires. I believe I got mine at autozone for around the same price.
Old Feb 1, 2010 | 04:20 PM
89native's Avatar
Car: 1989 firebird
Re: burning wires
thanx il looke for them
Old Feb 1, 2010 | 04:54 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: burning wires
whats done is done . you should have considered this before you installed the wires . i used the " made for you " brand from summit catalog . i'm very happy with mine . good luck on repairs .
Old Feb 1, 2010 | 06:53 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: burning wires
For stock manifolds try using a set of big block plug wires. They have strait boots and lay away from the manifolds.
Old Feb 2, 2010 | 12:47 AM
86T/A4001's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0L 305 TPI
Re: burning wires
I had the same problem, zip ties work wonders until you can find the right looms.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
