Re-using old pickup tube on Oil Pump??.
Old Feb 9, 2010 | 04:17 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..
Just a quick question here. I have amost rebuilt my 305 engine. Bought a rebuilding kit from federal mogul and with that kit came a high flow oil pump.
The pump didn't include any pickup, so I am wondering if I could just re-use my old one after some good cleaning of course??..
Or will it not flow good enough or what??..
Old Feb 9, 2010 | 09:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Re-using old pickup tube on Oil Pump??.
You could, but a new pickup screen is cheap.
Old Feb 9, 2010 | 10:09 AM
Twin_Turbo's Avatar
Either braze or tack it in place or expand the tube a little so that it sits tight in the pump, last thing you want is for it to rotate.
Old Feb 9, 2010 | 11:35 AM
Ok..Then I think I would just re-use it though, because there are no places in Norway that sells pick-up tubes. So then I have to buy one from US wich is no problem at all but it would take a couple of weeks to get it here to Norway and I am in a little of a hurry to get my engine together so I can start on my next project.Rebuilding the transmission..
Old Feb 9, 2010 | 11:36 AM
Ok..I think I would just use TIG and make a small "point" so I am sure they would stick together..
Old Feb 9, 2010 | 11:53 AM
kevins88ss's Avatar
I reused mine when I did my build. I put some black high-temp RTV around it and tapped it in using an open end wrench and a hammer. It's been fine with no issues. I was afraid to tack it with a welder as I'd probably just burn through the metal.
Old Feb 9, 2010 | 04:35 PM
Yeah I was thinking of that too..I pressed in the old pickup tube today at the oil pump and it was pretty stuck in there. But if I turned it hard I could twist it so therefor I used a TIG machine that we have at work and melted some metal down at a point so now it is locked and ready to be mounted.
Old Feb 9, 2010 | 05:39 PM
Twin_Turbo's Avatar
you did remove the bypass spring before welding right?
Old Feb 9, 2010 | 05:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And you set the height above the bottom of the pan correctly before you welded?
Old Feb 10, 2010 | 03:10 PM
I missed a little bit so I just cut up the welding and then re adjusted it so now it fits perfect..
Old Feb 10, 2010 | 03:11 PM
Didn't get any heat at all..the welding was done in about 5seconds so there was not any great heat at the iron..So the spring is the same colour with no damage at all
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
