Oil Leak and Running Issues... Help! *Pics*
Old Feb 12, 2010 | 01:02 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, so after a day at the track, I noticed my car running funny towards the end. I started leaking oil, and if I hold the gas steady at around 2.5k+ rpm it starts studdering, cutting out, and jerking alot.
I looked under my car and found this, what is it, and isn't something suposed to be attached to the bottom of it?
Old Feb 12, 2010 | 01:38 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Oil Leak and Running Issues... Help! *Pics*
i think that is the fan temp sensor.. not positive though
Old Feb 12, 2010 | 02:27 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hmm... What would cause that running issue then? I can find the oil leak in a few days. I am heading to oregon tomorrow for a few days.
Old Feb 12, 2010 | 12:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Anyone have any idea on the running issue? Timing? Fuel Pressure?
Old Feb 12, 2010 | 02:11 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, While adjusting my fuel pressure, I found that the distributor cap wasn't on tight. One of the screws is stripped on the body of the distributor, causing it to really wear the cap out on a few *****.
So I am going to get a new cap, and helicoil the distributor body and see how she does.
Old Feb 12, 2010 | 05:11 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Maybe check the valvecover--could be leaking thru the gasket due to not being fastened down enough?
Just a thought...
Old Feb 12, 2010 | 06:37 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, changed cap... Still running funny.
I noticed it is fine WOT just holding steady at around 2400 RPMs it jerks and cuts out..
Old Feb 12, 2010 | 07:03 PM
Car: '87 Camaro
The only things I would know to check would be---
rotor .. damaged, carbon, very well used
plugs.. oil//gas fouled, very well used
wires.. arcing against a header from a weak spot or burn-thru
ECM codes
Coil out-put
Other than that, IDK.
Old Feb 12, 2010 | 11:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
New rotor and Distributor cap...
Plugs aren't the newest... Im going to put some new ones in when I get back from oregon, and I am going to check and clean all my plug wires as well.
No SES light, but I am going to check the computer for codes tonight to see if it has any stored codes...
Car drives fine at WOT and if I keep it under 2300 RPMs, and it only jerks and misses at a certain RPM and RPM increase speed. I am going to keep driving it short distances, maybe it will throw a code or work itself out.
I noticed it was smoking alot at the track too, has me a bit worried as my engine only has about 20k miles on it at most, and it didn't have any smoking issues that bad until I hit the track. Car was running pretty good and I did get my best time too. I am going to check more into the smoking when I figure out the running issue.
Old Feb 12, 2010 | 11:16 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
the wiring in the pic doesn't look good. does the rest of the wiring look like that. could be part of the problem.
Old Feb 13, 2010 | 03:17 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
No, wiring is all good. It is just greasy and dirty. It is actually in good condition, except those few wires.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
