Pete Jackson Noisy Gears stay or go?
Old Feb 16, 2010 | 08:29 PM
rdicarlo's Avatar
Car: 1986 Camaro
Engine: 72 350 4Bolt Main from a C20
Transmission: 700R4 B&M Shift Kit tci converter
Axle/Gears: Borg Warner 9 bolt 3:42
Hi All,
My project Camaro is going in the shop for exhaust, bodywork and paint at the end of the month. They are going to also replace the timing chain cover with a chrome one and here's my chance to change out the noisy gears. The motor already had them installed when I got it and i was told that it's a fresh rebuild. I'm thinking about changing out the Pete Jackson Noisy Gears because people tell me that I'll get sick of the noise. What do you think, should it stay or go. I'm only driving the car to cruise ins and on weekends.
Thanks for the help,
Rob
Old Feb 16, 2010 | 08:33 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Pete Jackson Noisy Gears stay or go?
nice ride. looks like you painted an oil pan on your hood..lol it's personal preference. though you likely wont hear it from inside the car with a loud exhaust.
Old Feb 16, 2010 | 08:45 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
ditch it. They rob power anyway.
Old Feb 16, 2010 | 08:50 PM
rdicarlo's Avatar
Car: 1986 Camaro
What should I put in it's place???
Old Feb 16, 2010 | 08:53 PM
are you saying they rob power because they are heavier?
any good double roller will be fine
Old Feb 16, 2010 | 08:56 PM
rdicarlo's Avatar
Car: 1986 Camaro
I'm thinking about this one...
http://www.summitracing.com/parts/SUM-G6600/
Old Feb 16, 2010 | 09:51 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
And the wivestale repeats itself.It's a personal preference deal.it's never been proven in any dyno test I've ever seen that they rob one ounce of horsepower.I don't like them,because they are annoying.
Old Feb 16, 2010 | 10:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I had a noisy gear set in my race car for 1 day then yanked them out and put a chain back in. Even in the race car, I couldn't stand the noise.
Old Feb 16, 2010 | 10:08 PM
rdicarlo's Avatar
Car: 1986 Camaro
I'm pretty sure that I'm going to order this
http://www.summitracing.com/parts/SUM-G6600/ tomorrow to replace the gears. What do y'all think?
Old Feb 16, 2010 | 10:09 PM
Project-RS's Avatar
go with the double roller rob. my friends wouldnt tell me something if it wasnt a good idea
Old Feb 16, 2010 | 10:15 PM
rdicarlo's Avatar
Car: 1986 Camaro
I'm going with the double roller. So, the summit one is the best for the price?
Old Feb 16, 2010 | 10:19 PM
Project-RS's Avatar
yea. its almost half price rather than the edelbrock one
Old Feb 16, 2010 | 10:20 PM
rdicarlo's Avatar
Car: 1986 Camaro
I have a Crane Cams Energizer Cam 282 duration 516 lift exhaust 482 intake in a 1972 4 bolt main 350, if it matters...
Old Feb 16, 2010 | 11:15 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
try www.pawinc.com they have great prices too!
Old Feb 17, 2010 | 04:57 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Actually i have dynoed motor to see if this was true and it did lose 4 hp at peak, not alot, no but some. Yes go with the summit chain.
Old Feb 17, 2010 | 05:09 PM
rdicarlo's Avatar
Car: 1986 Camaro
What do you think about this one?
http://www.summitracing.com/parts/ZZZ-160001
Which one is better?
Old Feb 17, 2010 | 11:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Just get a Cloyes set that's best suited for your application. Even a Cloyes bottom end set is still more than good enough to use.
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
