need head number help
Car: 1985 Chevy Camaro
Axle/Gears: 3.08
so i bought this motor out of an old nova and the guy said he doesnt know if its origional or not. i think it has been rebuilt for sure but i really cant find anything on the heads the number is 3888336 has anyone ever used this head and if so are they champs or are they chumps. oh and i belive it is a 350 2 bolt but i really dont know the difference by looking so it may be a 350 4 bolt
Axle/Gears: 3.08
head cast number help please
i bought a motor out of an old nova. 350 sbc. i cannot find any info on the heads on my new motor the number is 3888336 does anybody have any info on these heads are they chumps or are they champs
thanks
thanks
Transmission: 4L80E/4L80E
Those casting #'s can be hard to distinguish. Any chance it is 3986336?
"Old Nova" makes "chump" much more likely.
You can't tell 2- vs. 4-bolt from the outside. You need to pull the oil pan and look.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need head number help
https://www.thirdgen.org/forums/post...270-post8.html
Should be 2 bolt mains; check block #
The block casting # doesn't necessarily tell you whether or not it is 2- or 4-bolt.
Car: 82 Z28
Transmission: T400
That's the only place that I could find with that information. Makes it suspect to me. Truck 350's typically had 4-bolt mains.
But, at any rate, you can pretty much assume that any early 70's factory truck heads are better door stops or boat anchors than heads to use on a performance engine. Don't have hardened exhaust valves or seats, if you need a reason not to use them. Large chambers and small valves are another couple good reasons to toss them.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
