Piston Picture?
Old Mar 3, 2010 | 12:33 AM
RyanZ's Avatar
Car: 1986 Camaro
Engine: 355
Axle/Gears: 4.55
Piston Picture?
Is anyone runninga speed pro h631p pistion that has a picture of it installed in the block? if so can you post the picture for reference?
Old Mar 3, 2010 | 09:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Piston Picture?
What is it you need to see in the picture?
Old Mar 3, 2010 | 09:38 AM
RyanZ's Avatar
Car: 1986 Camaro
Engine: 355
Axle/Gears: 4.55
Re: Piston Picture?
i need to see where the valve reliefs are. on my engine the valve reliefs are to the outside and that doesnt seem right thats why i wanted to see a picture
Old Mar 3, 2010 | 03:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Piston Picture?
Valve reliefs go towards the inside.
Old Mar 3, 2010 | 05:23 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Piston Picture?
bearing tang on the rod always goes towards the outside.
Old Mar 3, 2010 | 05:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Piston Picture?
Or "down", whichever's easier to think of.
Old Mar 4, 2010 | 12:47 AM
RyanZ's Avatar
Car: 1986 Camaro
Engine: 355
Axle/Gears: 4.55
Re: Piston Picture?
alright thanks guys looks like its a good thing i double checked turns out theyre in backwards. can i turn them around in the hole without actually taking the head off if i put the crank as far away from the hole as possible?
Old Mar 4, 2010 | 10:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Piston Picture?
You could, but your ring gap position would be messed up.
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
angel2794
Sep 8, 2015 06:22 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
