head gasket fix in a bottle???
Old Mar 6, 2010 | 02:14 AM
86_Dan_Z28's Avatar
Car: 86 Z28
Anybody ever heard of this stuff called "steel seal"? They claim that it can fix a blown head gasket. It sounds too good to be true.
http://www.steelseal.com/
Old Mar 6, 2010 | 09:56 AM
Vader's Avatar
Re: head gasket fix in a bottle???
Head gasket fix in a bottle? It might work, as long as you are in Ohio and the bottle looks like this:
Honsetly, I doubt that you will have much success. It may temporarily slow the problem but you will eventually have to repair it properly. It would be a really good excuse to do some other mods, like a little bowl and pocket porting, valve upgrade, screwed studs, and give you a good look at the bore wear and taper.
Old Mar 6, 2010 | 12:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It does not work. Due to cheap customers I have used all kinds of quick fixes at request. I got the head gasket in a bottle to "workish" one time it was some blue crap $40 for a tiny bottle. I followed directions to a T and it held over night.
Old Mar 6, 2010 | 03:09 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Stuff seems to me to be a "get you to the shop" kind of fix. Just like most other sealants including that tire inflate-n-seal stuff.
Old Mar 19, 2010 | 09:30 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
My thing is if it gunks up a hole or leak, Who knows what else it will gunk up in your motor.
Old Mar 19, 2010 | 10:26 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
My grandparents used it once to get their DOHC 2.7L V6 intrepid to the dealership for a new car. haha. The dealership turned around and sold the car 1 week later (not sure if they fixed the head gaskets or not)...poor sap
Those head gaskets are a BITCH! I did them once and that was the last time.
Old Mar 19, 2010 | 10:31 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
waste of money, just do it right. head gaskets aren't that bad.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
