To retard or advance that is the question.
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Which makes the car easier to start more retarded timing or advanced?
Thanks, Chas
Thanks, Chas
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: To retard or advance that is the question.
none of the above. timing needs to be close to perfect for the engine to start easily. highly advanced timing will make the engine lock when starting.
Car: 86' IROC
Engine: 388
I'm not flooding out the engine, I just give it a little tap on the gas while cranking or it wont start at all...I also dont have a choke but shouldn't need it for the temps i drive in. My fiancee gets worried when it doesn't start right up like her little Pontiac Vibe.
Could having stock starter with 11:1 compression be the culprit?
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Jake
Transmission: 4L80E/4L80E
Car: 86' IROC
Engine: 388
o ok...o well ill just deal for now...the guy i bought the carb from removed the entire choke assembly...i was going to buy a aftermarket proform or holley main body anyway.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Car: 86' IROC
Engine: 388
2012sergen11
Oct 13, 2015 07:38 PM
