Car Starts...Then Dies help!
Car: 87 Camaro
Engine: 383 Stroker
Hello All,
well i have a '87 camro coupe, 305 Carb
it ran fine for awhile untill last weekend, it turns over and you have to floor it to get it started and once it does start it just dies again
my thoughts are a stuck choke, or leak?
any ideas??
thanks
any ideas??
thanks
Transmission: 4L80E/4L80E
If you have to floor it to start it, that's either flooding or a stuck/non-operating choke.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Car Starts...Then Dies help!
do you have any more info on your set up? sounds like a carb or fuel pressure problem. just prop your choke open to rule out the choke.
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
I agree it sounds like the carb isnt getting enough fuel and when you flooring it, enough builds up to crank but not enough maintain it.
Car: 87 Camaro
Engine: 383 Stroker
my understanding is if its only a choke problem that if i can feather the throttle and keep it going untill it warms up it should be fine. i hope it is just that though
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
if you get black dark smoke when this happens, then it's your choke... I had a similar problem...
then the choke is definitely the place to start, I dont know about your exact setup but you should be able to replace it, or bypass it, or rebuild it, it might be that its just stuck on
db057
Aug 11, 2015 10:11 PM
