slight hesitation at idle after warm up
Old Mar 18, 2010 | 10:25 PM
Gatorsfan91z28c's Avatar
Hey guys! Thanks already for any ideas. I have a 91 camaro z28 with the 305 tpi. It idles perfect when cold, but when it has warmed up there is a slight hesitation every 5 or 6 seconds when idleing at a stop light with the brake pedal applied. I cant find any vacuum leaks. I recently replaced the O2 sensor which cured the rough idle that I was experiencing in the same situation, but there is still a little hesitation left. The car was running rich and throwing code 45 before the sensor change. Thanks again.
Old Mar 18, 2010 | 10:28 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: slight hesitation at idle after warm up
have you tried cleaning your TB...
Old Mar 18, 2010 | 10:33 PM
I sprayed throttle body cleaner in the throttle body last year, but I dont know if that cleaned it good enough. I heard that sea foam poured into a vacuum hose like the one connected to the brake booster does a good job at cleaning the intake etc.
Old Mar 19, 2010 | 11:03 AM
hurd85ta's Avatar
Car: 85 trans am
Engine: 305 tpi
Transmission: 5 speed
sea foam cleans the cylinders, valves stuff like that.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
db057
Sep 4, 2015 07:57 AM
IROCtometal
Sep 2, 2015 02:01 PM
