accelerates on it's own.
Old Mar 20, 2010 | 11:42 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I Recently got a 1991 firebird 5.0 tbi. after a few days of having and after cleaning a few things in the engine bay; it started accelerating on it's own.
i let it sit in drive without touching the gas; it starts speeding up. it's gotten to 30mph on it's own. it also idles funny. it rev's on it's own and it has a high idle at 1000rpm. i really dont know what to do.
Old Mar 20, 2010 | 11:45 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: accelerates on it's own.
im guessing it was made by toyota! sorry i have no clue. hope ya find out. ttt
Old Mar 20, 2010 | 11:46 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Check your vacuum lines to make sure they are still connected and not leaking. If you need to spray some carb cleaner/starting fluid/brake cleaner around the lines, if the engine revs while spraying it has a leak.
1k rpm idle isn't high, mine is 900.
Old Mar 20, 2010 | 11:50 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
ill try that tomorrow morning. well when i have my foot on the break it feels like it's trying to peel out with out me steeping on the gas.
Old Mar 20, 2010 | 11:53 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
a vacuum leak will cause a rise in rpms but it all depends on the size. Fuel injected or carb car?
Old Mar 20, 2010 | 11:55 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
throttle body injection
Old Mar 21, 2010 | 12:14 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
make sure your TB is shutting all the way too.
Old Mar 21, 2010 | 04:36 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Beat me to it god damn you!
Old Mar 21, 2010 | 06:51 AM
bcmag's Avatar
would pay close attention to tbi mounting gasket.if memory serves me right these had a high rate of failure.also depending on how vigorously you cleaned may just need to dry out.depending on condition of harness water can cause voltages to bleed across wire at multi connectors.
Old Mar 21, 2010 | 09:09 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I beleive you are right. i did remove the tbi but i never replaces the gasket, and i did clean it too hard (pressure washer) ...
Old Mar 21, 2010 | 06:55 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Foster382!!
Pressure washers are bad for electical componets, like the TPS!! I pressure washed a 2.8 multi port, and got some water into the TPS, made it rev like it was going racing!!
Try drying out the TPS with a hair dryer or a heat gun (on a low setting), it may solve your problem!!
Old Mar 21, 2010 | 09:42 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
TPS? thats the throttle position sensor, correct?
Old Mar 21, 2010 | 10:18 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Si
Old Mar 22, 2010 | 12:09 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Id check the IAC
Old Mar 22, 2010 | 07:24 PM
Hello Foster382!!
Yes!! You are correct, see itsMikey's post, he confirms it too!!
Did you have any luck???
Old Mar 26, 2010 | 05:49 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Originally Posted by 87IROC-DAN61
Hello Foster382!!
Actually yes. it is a problem with the TPS. to my findings is that it sent an error code to the ECU, BUT the check engine light never came on. So the people i bought it from have unpluged the engine light. It's a good thing i never got my inspection yet and to still be in auto Tech.
Old Mar 26, 2010 | 01:21 PM
Hello Foster382!!
Now that you know it's the TPS........$25.00?????, and your good to go!!
Just speculating on the price for a new one...........bought one in 1993?, for about that$$$$!!!
Old Mar 26, 2010 | 08:31 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Thanks Yal. It runs so much smoother now. it went from accelerating to 30 on it's own to 10mph drift.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
FormulaEngland
Sep 30, 2015 01:50 PM
ULTM8Z
Sep 16, 2015 09:15 AM
