87 vortech cam
Old Mar 23, 2010 | 09:31 PM
speedy2you's Avatar
Car: 1982 chevy z28 camaro
Engine: 350 vortech
Transmission: auto 350 turbo b\m shift kit
Axle/Gears: stock
87 vortech cam
i have a 82 z28 and it has a vortech 350 and im thinking about re building the top end do i need to look at rolling lifters or is is aflat tapper i know its a new motor but how can i tell what year this motor is i now its vortec and how can i tell if it came out of atruck or car it has no tbi.however it got a hei dist and a eldabrock intake and a rochester 4bbl so what parts do i need to get
Old Mar 23, 2010 | 10:06 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Re: 87 vortech cam
Vortec 350 didn't come out till 96. If your 87 engine is out of a truck, then it would have a flat tapper. If it came out of a car, it more likely has a roller cam.
Old Mar 23, 2010 | 11:09 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
how can i tell if it come out of a truck or car it has not got a tbi on it any more it as eldebrock intake and carb and a hei dst
Old Mar 23, 2010 | 11:14 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
Old Mar 23, 2010 | 11:41 PM
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Re: 87 vortech cam
The block number will tell you, if it was a truck motor or not, and it will tell you if it orginally came with a flat or roller cam.
Old Mar 24, 2010 | 12:26 AM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
weres the block # on back
Old Mar 24, 2010 | 12:56 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 87 vortech cam
Usually on the side of the block. Look above the oil pan on the side.
Old Mar 24, 2010 | 03:41 AM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
Re: 87 vortech cam
A picture says more then a thousand words:
Old Mar 24, 2010 | 11:28 AM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
do i just call chevy when i get the numbers and do i need both
Old Mar 24, 2010 | 12:18 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: 87 vortech cam
post them up here and people can tell you what they are
or go to www.mortec.com
Old Mar 24, 2010 | 01:49 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
thanks guy all have to pull my valve cover to get were i can see them but thanks alot i just post them when i get a chance thanks alot
Old Mar 24, 2010 | 03:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, it won't. It may tell you if that particular casting was flat-tappet only, or could have been roller lifter, but it won't tell you if a potentially roller lifter block was used as a roller lifter or flat tappet engine. Trucks and passenger cars used the same block castings.
Old Mar 24, 2010 | 05:10 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
so would it be that i will just have to pull it apart to find out now im just wandering if a 305 or a350 the one i got it from said it was a 350 i wish there was another way to tell without cking the cast #
Old Mar 24, 2010 | 05:43 PM
Car: 1992 Camaro RS
Re: 87 vortech cam
350s and 305s are externally indistinguishable. There is no way to tell. newer blocks have the displacement stamped on the back of the block (see the pic that was posted?). I would bet if it doesnt say 5.0 or 5.7 on the back of the block it's llikely a flat tappet block. Where's the dipstick? Is it a 1 pc or 2 pc rear main seal? If you dont know, look at the back of the oil pan hwer the crankshaft comes out and see if it has a perfectly round flange for the flexplate to bolt to, or whether it has a weird rectangular tab on one side. If it is the latter, then its most likely a 2 pc RMS block which isnt a roller block.
Get the head casting number. If it's been rebuilt it wont tell you much, but it can be a big hint. All those things should point to something.
Old Mar 25, 2010 | 07:47 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
thanks guy yall been a lot of help i just pull the covers so i can see the block # since the motor still in the car
Old Mar 25, 2010 | 08:16 PM
five7kid's Avatar
Re: 87 vortech cam
You can tell a 305 from a 350 externally by the block casting #.
(BTW, we are talking about whether or not this is a "Vortec" engine, right? Not whether it has a "Vortech" supercharger?)
Old Mar 25, 2010 | 10:27 PM
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Re: 87 vortech cam
The O.P. is wondering if he needs to buy roller lifters or flat tapper lifters, since the 87-99 engine blocks could have used either.
Old Mar 26, 2010 | 12:46 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: 87 vortech cam
Only way to really know is yank the intake mani. if it's carbed that's like 20 minutes and 20 bucks in gaskets.
Old Mar 26, 2010 | 12:48 AM
five7kid's Avatar
I hope somebody has a map, because I've completely gotten lost in this thread.
Do you want to know what lifters your engine has now? If it came from an '87 truck, it's flat tappet (and not Vortec). If it was a Vortec engine, it had to be from a '96-'99 truck (a few '00's as well), and it would have roller lifters.
What lifters you might be able to use in it is a completely different question. . .
Old Mar 26, 2010 | 10:40 AM
Grumbles's Avatar
Re: 87 vortech cam
if I'm not mistaken, can't you go from roller to flat tappet just by ditching the spider and dropping in flat lifters?
Not that you'd want to, just curious if I'm correct.
Old Mar 26, 2010 | 06:00 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
i guess i just pul it when i can get a chance and get the block number then i guess will know all then thanks guys sorry for the the wild goose chase but its a my only daily driver so it may be a while before i know i was triying ti find out what size and what type upper rebild kit i would need thanks for all your help im still new on this site
Old Mar 26, 2010 | 07:13 PM
Grumbles's Avatar
Re: 87 vortech cam
Uh well unless you plan to replace all the lifters it wouldn't really matter I dont think. Getting any valve train noise? if not, I'd say just stick with the lifters you have.
Old Mar 26, 2010 | 09:49 PM
speedy2you's Avatar
Engine: 350 vortech
Axle/Gears: stock
Re: 87 vortech cam
yea they rattle alot when on the 4bbl and the valve seals gotten to were they leak and cause it to smoke i even use 89 octane and they still rattle and use 20w50 thats why i put the trend up so i could find out what i need to buy to repair it in one day because and can't be down long its adaily driver and my only one so thats why its important that i find out but thanks for all the advice everybody
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
