Head gasket question
Old Mar 29, 2010 | 08:17 AM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
Built a 350 .040 over, flat tappet cam engine, with World Sportsman II heads (untouched, no port work). These are the head gaskets that I used http://www.summitracing.com/parts/FP...s/?prefilter=1 .
Did i f*ck up and use the wrong head gaskets?? All i wanted was a slightly thinner gasket (for obvious reasons) that would accomodate the slightly larger bore.
The car runs real cool, and takes a while to warm up, but im running a larger after market radiator, and have a stock 305 TBI elec fan with a trans cooler fan. If i start it up and let it run for like 2 or 3 minutes and shut it off i can hear the coolant like bubble (like there air pockets even though the engines been run plenty to get that out) however once the car has started to reach normal operating temp and i shut it off, it wont make any bubbling sound??
Old Mar 29, 2010 | 08:33 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Head gasket question
do you have an overflow reservoir? or if you do does it have coolant in it? if not it may have pulled some air in. i hope your block isnt 0 decked with that head gasket. you need a min 0.030" between the piston and head.
Old Mar 29, 2010 | 10:16 AM
Rob 97 Z28's Avatar
Yes, I have a stock reservior, and its got plenty of water in it. No the bolck was just cleaned up, didn't need anything just a a slight hone to clean up the walls if i remember correctly and that was it.
Old Mar 29, 2010 | 12:52 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I run the same gasket, I've never had any problems.
Old Mar 29, 2010 | 01:57 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
...that gasket is fine.
My car never gets over 140 degrees with my aluminum radiator. Alas
Old Mar 29, 2010 | 02:59 PM
Rob 97 Z28's Avatar
Thanks guys! I appreciate the quick response gives me piece of mind!!!
I called their tech line and guess they're okay but i was warned about making sure the deck hasn't been zero'ed out because they are only .015 thickness compressed. This worries me because i have to adjust my valves sometime this week and adjusting 1.6 RR is not the same as stamped steel 1.5s. I tried all afternoon yesterday and they all seemed way to loose, but im worried bout going anything past 1/2 turn IR my PtV clearance is that tight with these head gaskets....
Old Mar 29, 2010 | 03:38 PM
you'd be surprised how much valve piston clearance you may have. i 0 decked my block and still have .200".
Old Mar 31, 2010 | 08:58 AM
Rob 97 Z28's Avatar
I didn;t think i'd have real clearence issues considering my cam http://www.summitracing.com/parts/CCA-12-365-4/ but i panic'd. Adjusted the valves using this method http://www.chevyhiperformance.com/te...nfo/index.html so we'll see how this works out.
Old Mar 31, 2010 | 07:52 PM
Rob 97 Z28's Avatar
Great method to adjust valves to! Worked like a charm
Old Jun 23, 2010 | 02:00 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
How do I make the head gasket match my.60 bore i got the seal kit for a stock engine.
Old Jun 23, 2010 | 02:36 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Head gaskets are made with a bit of clearance around the cylinder bore, sufficient to allow for overbore applications. Match the gasket to the block by laying it down on the dowels. You should see deck surface around each cylinder with the gasket laid flush against it. If so then youll be fine.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
