I'm killing plugs please help
Old Mar 31, 2010 | 09:41 AM
engineer1matt's Avatar
Car: 1982 Camaro
Engine: SB 427 supercharged
Transmission: Turbo 350
Axle/Gears: Ford 9in, 4:11
I have an 82 camaro it has a small block 427 with a wieand 142 supercharger I cant find a plug that works between 0 pounds of boost and 3 pounds (above atmospheric pressure) I keep fouling them out. Im going to rebuild the carb just to make sure Im getting the right fuel mixture since it has sat for 2 years. I also have to adjust the mechanical lifters but Im just trying to see if anyone has any plug ideas currently using R45TS. Any help would greatly be appreciated.
Old Mar 31, 2010 | 09:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: I'm killing plugs please help
If you're fouling that hot of a plug, try more spark advance. You may need more octane.
Old Mar 31, 2010 | 09:52 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It's probably the fuel you're using burning too slowly or cool.
You must be using race gas, alcohol, or you're mixing in a lot of Xylene or Toluene.
The fuel that works at WOT under boost will not also work well when your cylinder pressure is very low.
Low compression and poor quench aggravate this problem.
At idle and cruise you need to try to lean your AFR to at least 15.5:1 or higher with as much spark advance as you can use without knock.
If this is happening with regular pump gas, then it's likely that your spark advance is too low for efficient combustion.
A dual fuel system - one for non boosted driving, is one solution.
Also keep your plug gaps tight at around 0.030".
Old Mar 31, 2010 | 10:04 AM
Car: 1982 Camaro
Thank you both. I'm currently using 93 octane. The motor is 10.5:1 before the supercharger is added I'm not sure on the math but I think it changes to about 12.58:1. I will diffidently try the spark advance.
Old Mar 31, 2010 | 10:08 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I was thinking pump gas, I didn't even consider any alcohol-based fuel.
Old Mar 31, 2010 | 12:12 PM
Car: 1982 Camaro
So the conclusion is keep the same plugs tune the motor?
Old Mar 31, 2010 | 12:16 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i would still check the carb. check float level and power valve
Old Mar 31, 2010 | 12:18 PM
Car: 1982 Camaro
holly 750 double pumper not sure on the jet size another reason I was going to go though it.
Old Mar 31, 2010 | 06:41 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
fouled plugs is caused by too much fuel, but since you said you'd be doing the carb, I didn't see any need to suggest that. If it fouls after you get the carb right, then play with timing.
Old Mar 31, 2010 | 07:24 PM
Car: 1982 Camaro
Thank you I will wait until Im done with the carb to see how it runs I hope to have it on the road soon spring is here and I have the itch.
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
