Quick question- What is this sensor?
Old Apr 8, 2010 | 01:33 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
What is the sensor located between spark plugs 6 & 8 on a chevy 305? I was replacing the spark plugs and my universal joint caught it and broke it
Old Apr 8, 2010 | 01:35 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Quick question- What is this sensor?
coolant temp sensor for the gauge
Old Apr 8, 2010 | 01:40 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Is there more than one of those? Because I fixed my temperature sensor on the driver side of the block (between 1 and 3) earlier this year
EDIT: To further clarify, I had no temp on my gauge earlier this year, and when I mended the wire that ran to the sensor (between 1 and 3) I had a working temperature gauge
Old Apr 8, 2010 | 01:49 PM
is this a FI engine? if so you have 2 temp sensors, 1 for the gauge and 1 for the ecm. the gauge is a 1 wire sensor, the ecm is a 2 wire sensor.
Old Apr 8, 2010 | 01:51 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Nope, has a carb
Old Apr 8, 2010 | 01:55 PM
should be a plug there. maybe the heads were off once and put put on the opposite sides. what was connected to the sensor? do you have a pic of it?
Old Apr 8, 2010 | 02:18 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
I won't be able to get a picture of it today, but there was a plug on it, I just broke it. I tested and I to have temperature on my gauges. Are both plugs the same type?
Old Apr 8, 2010 | 02:34 PM
does the car have electric fans? which connector is it?
Attached Thumbnails Quick question- What is this sensor?-5640x1__51835_zoom.jpg   Quick question- What is this sensor?-g1852.jpg
Old Apr 8, 2010 | 02:43 PM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
The first one, nonmetal. Yes for electric fans
Old Apr 8, 2010 | 03:21 PM
the fan switch should be in the top of the thermostat housing. i think there should also be a knock sensor in the block with the same connector.
Old Apr 8, 2010 | 03:23 PM
fan switch
Old Apr 8, 2010 | 03:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not a sensor, it's a thermal switch. It's for the radiator fan, turns it on when the coolant gets to 238 degrees F (or something like that) by providing a ground for the fan relay magnet circuit.
Old Apr 9, 2010 | 09:12 AM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
Wow thanks a lot guys!
One last thing, is it possible just to get a new wire?
Old Apr 10, 2010 | 01:00 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello ROFLsplash!!
Yes, your local GM dealer has replacement pig tails for sensors like these!!
Also, there is a place called eficonnection.com they should have it also!!
Their website is down until April the 12th, new and improved web site coming!!
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
corey8084
Sep 17, 2015 02:56 PM
mackjar66
Sep 14, 2015 01:17 PM
